Ok, Thanks Jason.
I'm going to pick up a new battery tomorrow. Mines shot and I'm experiencing a HUGE voltage drop at my amps. Its not letting my amps and new x reach their potential.
Angle is fine. When the sub is down on that well area you can fire it down or to the side and it will all sound good.
I think I will make up the cable this weekend and take pics.
1999 Black Pontiac Trans Am
CarPC's in F-bodies
How To Relocate Climate Controls on the 97-02 F-body Cars
(AMD Sempron 3000+, Opus 150)
Car PC system is out, Alpine system is in.
Ok, Thanks Jason.
1998 Camaro Worklog Starting over, New setup for 2010
The sealed Optimas are real sweet. No corrosion on the terminals, ever.![]()
CarPC's in F-bodies
My Worklog
I'm using my carputer 100%, but I still need to make it easier to use.
I was looking at those Jason, but i'm going to get a generic battery for under the hood, and add the deep cycle in the back. I don't think i'm going to go with any big names for either because i can get a nice deal on both here in town.
Thanks for the kind words moboman. I'm trying to make it that way atleast![]()
Are you going to isolate them? If not then they need to be identical to one another.
CarPC's in F-bodies
Yea they will be isolated from each other. I'm looking for something that'll only allow a trickle charge to the deep cycle for when it's completely dead. I don't want to try to start my car on the main battery and have a huge draw to the deep cycle battery. Any ideas?
BTW i picked up my main battery today 825 ca and 690 cca. A friend of my dads owns a construction company and has a nice discount (25%)
Are you going to use a diode type isolator? If so and your starter is wired to the main battery then I don't think it will draw from the rear battery during starting. The only thing is a diode type isolator is going to charge both batteries at the same time, so that's why they would need to be identical.
So were you going to use a solenoid type isolater so you can have manual control or what exactly?
Dual batteries are a pain, no doubt about it. A good, but expensive way is to run a dual output alternator, but they are very expensive. I haven't made up my mind yet, but if I run dual batteries, I'm also going to run dual alternators. It's a lot cheaper and you get a lot more power. There is room to mount the 2nd unit above the tensioner pulley. I have pics if you want to see them.
CarPC's in F-bodies
Jason, When you say the batteries are identical, are you saying that both ave to be regular starting batteries? Because for marine usage someone makes an isolator made that you use your alternator to charge a deep cycle for the trolling motor of your boat. Both batteries are not the same here.
I want 2 batteries too and I was planning on putting one in. I want to do a little more research now that you say they have to be the same.
My Worklog
Yea i would like to see those pictures. I was looking into the high output alternators, but i can get mine beefed up to a 150 amp and then get a second one done like that eventually. I think that would be better than a 200 amp high output.
I'm looking at a solenoid type isolater that would be relayed off the ignition. It would of course have a switch in between the ignition and the solenoid for when i want to turn the car on but not give power to that battery. With a solenoid type isolater you don't think that the power will try to flow into the deep cycle as soon as i give the solenoid power? I think the easiest thing to do is what you said with the dual alternators and have one for each battery. thats just more moneywhat an expensive hobby
and i also want to save for another x and one of these
Memphis 16-MCD2500 - Memphis 2500 x 1 Class D Subwoofer Amplifier
2500 watts x 1 RMS @ 1 ohm
or something with the same specs made by Us amps, Orion or a few others. I figure I need an amp that can give me the clean power that the x's need.
