Page 22 of 45 FirstFirst ... 121314151617181920212223242526272829303132 ... LastLast
Results 211 to 220 of 442
Thread: 1998 Camaro Install- lots of pics, rear seat delete
  1. #211
    Oct 2005
    Hou. TX
    Quote Originally Posted by sporty_drew View Post
    What do you think about that box design jason? I'm worried that 2.5 inches on that shallow part might not be enough, but i haven't found anyone that knows or not so i'll pry just build it and see.
    Will they even fit in that shallow of a spot? I'd raise it to 5 or 6" if possible. Why did you decide on 4"?
    Now if you have the magnets on top, then 2.5" should be fine.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  2. #212
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    Quote Originally Posted by JasonWW View Post
    No they wont fit in 4 inches the subs are 7 5/8 inches deep. The front two will be inverted while the back two will be mounted regularly. I decided on 4 inched so the box doesn't stick up really high and can be blended in with the rear hatch panels. I was worried about when i had the box split down the middle whether or not they would see the same amount of air.
    1998 Camaro Worklog Starting over, New setup for 2010
  3. #213
    Oct 2005
    Hou. TX
    Why split the box?
    Does the 2 subs up and 2 down look good?
    CarPC's in F-bodies
  4. #214
    Mar 2006
    Iowa
    I firgured i'd be able to make sure they saw the same amount airspace if i split it strait down the middle (one inverted, one not).
    I think it'll look nice with two inverted and two not. I'm even thinking about floating the sub amps above the back two if i decide to put my rear seat back in.
  5. #215
    Oct 2005
    Hou. TX
    Why do you want to split the box into 2 seperate chambers? Just leave it one big chamber.
    CarPC's in F-bodies
  6. #216
    Mar 2006
    Iowa
    so you think all 4 would see the same amount if i left it as one chamber as compared to 2?
    If i leave it as one all i'll have to do is add some bracing in the middle.
  7. #217
    Oct 2005
    Hou. TX
    Yes and I would add crossbracing in several areas to make it very stiff and rigid. That should work fine.
    CarPC's in F-bodies
  8. #218
    Mar 2006
    Iowa
    sounds like a plan. Now i need to sell this setup
    I have one of my 4 r's so far.
  9. #219
    Mar 2006
    Iowa
    I've decided since i've been doing all the saving i can and trying to make some money other ways to build my new setup that'd I would start working on something that wouldn't cost much. I Extended the display off of my base scanner i have. My initial plan was to make all of this into a 1 din unit and use it to replace my processor, but i'm starting to think that i'll put it (just screen and 2 knobs) in my rear view mirror. That way i'll be able to put my alpine c701 i plan on getting (later on) in the one din spot. I might do it vise-versa (and be able to keep keypad), we shall see what happens.
    It took 32 wires (four 8 foot runs of cat5) and a bit of soldering and this is what i came out with. . .the pictures (please pardon the soldering skills, yet again)
  10. #220
    Oct 2005
    Hou. TX
    What do you use that for?
    Think your car will be louder than mine?
    4 type r - ? watts
    3 jbl gti - 2200watts
    We should be disturbing the peace for sure.
    CarPC's in F-bodies
  1. 2002 Camaro Install
    By Z28CTYHNTR in forum Show off your project
    Last Post: 12-19-2006, 04:56 PM
  2. I want to install a switch
    By Froogle in forum Power Supplies
    Last Post: 04-13-2006, 11:12 PM
  3. 78 Camaro Type LT install.
    By hcker2000 in forum Show off your project
    Last Post: 12-31-2005, 08:29 PM
  4. 1998 Honda CRV Headunit-less install
    By hihidamon in forum Show off your project
    Last Post: 02-24-2005, 05:38 PM
  5. Please help install a Front End
    By Zebelkhan in forum Newbie
    Last Post: 01-31-2005, 06:40 PM
