i always think of macho man randy savage's sunglasses from the 80's when i see that wrapping on cars. in both cases it shocks me that someone can actually see out!
1998 Camaro Worklog Starting over, New setup for 2010
1999 Black Pontiac Trans Am
CarPC's in F-bodies
How To Relocate Climate Controls on the 97-02 F-body Cars
(AMD Sempron 3000+, Opus 150)
Car PC system is out, Alpine system is in.
Dude, I don't think I could handle 5" of snow. It barely gets down to freezing here.
I took pics of the cable as I put it together and will do part 2 of the writeup. At first I taped over the sheath and the plastic tubes that connect them, but it seemed weak, so I got the strongest, stickiest tape I could find. I used double side tape for car side trim.That stuff sticks good. I also pumped the middle extension sheath full of grease from a grease gun. It feels like a stock cable does when turning it.
You can also adjust the knob position if it's off a little by lifting the spring out of the big end and rotating the big round disc a tad then putting the spring back in. See the plastic tab in the middle of the spring? That and 2 smaller tabs you can't see act as adjustors and keep the spring from slipping.
CarPC's in F-bodies
The pic above is an old one. My crimps are a black and longer, but it pretty much looks the same. I'll post the pics tommorrow. The sheath has a few bulky spots where the tape is wrapped around it, but it should all fit under that black plastic panel under the dash.
CarPC's in F-bodies
It's not the prettiest looking thing, but hey, it will be hidden.
Main thing is it will work.
CarPC's in F-bodies
haha, thats all i need![]()
