Page 27 of 45 FirstFirst ... 171819202122232425262728293031323334353637 ... LastLast
Results 261 to 270 of 442
Thread: 1998 Camaro Install- lots of pics, rear seat delete
  1. #261
    Oct 2005
    Hou. TX
    Man, you stay up late. You work nights like me?
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  2. #262
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    i have class from 8:00-5:00 and then work from 5:00-11:30. The snow killed me today because we got rain first and then snow and more rain. It made for some heavy shoveling.
    What do you do?
    1998 Camaro Worklog Starting over, New setup for 2010
  3. #263
    Mar 2006
    Iowa
    I got the cable today. I hope to get a chance to get it installed tomorrow.
    I'm having electrical problems
  4. #264
    Oct 2005
    Hou. TX
    How does the tension on the spring look?
    The first 24 hour period: the tension left
    I cut off the ends and crimped new ends tighter.
    The 2nd 24 hour period: still nice and tight
    Then I shipped it out. I don't know where the slack came from, not the crimped ends, so maybe the cable itself. Hopefully it is all stretched out and will not stretch anymore.
    Do you have the electrical stuff sorted out?
    CarPC's in F-bodies
  5. #265
    Mar 2006
    Iowa
    Quote Originally Posted by JasonWW View Post
    The tension looks and feels great. It must have been the cable itself.
    My electrical problems seem to be too much draw on my system. The cold weather kind of put me over the limit for draw. I'm going to see how big i can get my stock alt rebuilt (dad has a friend) before i buy a 160 amp online.
    I'm planning on getting 0/1 gauge from knukonceptz.com (for big three and run to back)
    then a battery isolator and a deep cycle for the back.
    I hope that'll get me thru the winter.
    I've been driving without the system just so that i don't get stuck somewhere with a dead battery and being cold.
  6. #266
    Oct 2005
    Hou. TX
    Have you considered one of those portable jumper batteries? They've saved my bacon quite a few times.
    Speaking of isolators. You know how they drop your voltage? Since both the car and the stereo will see lower voltage, I wonder if you could order an alternator or modify one to supply 15.5v? I forget what the voltage loss is, but something that will make the car and the stereo see their regular 14.4 volts max.
    CarPC's in F-bodies
  7. #267
    Mar 2006
    Iowa
    I've thought about those jumper batteries, but i haven't ever heard how well they work (till now)
    I'll have to do a little more research on the isolators and ask mel (shop owner) what he can do for me when it comes to that. How do alot of people run deep cycles in the back? Just have a sylinoid on the wire run to the back? I thought that having an isolator would be the safest way.
  8. #268
    Oct 2005
    Hou. TX
    I think most people use an isolator. If the alternator is putting out 14.4v the rear will still see 13.2v or so. I think it's a 1.2v drop or something close to that. With the engine off it's going to have the regular voltage of 12.2v or so. They work, you just lose some voltage. If your not trying to squeeze every last bit of power from your amps, then it should be fine.
    If your main battery goes dead, you can jump the 2 batteries together to crank the car.
    How do you know your overpowering your alternator?
    CarPC's in F-bodies
  9. #269
    Mar 2006
    Iowa
    13.3 wouldn't be bad since my sub amps rated at 12.5v it benches are 1700-1800 at 14.4v
    From what I've read alot of people tend to just use big relays. wouldn't that be bad since it doesn't control backflow? Maybe I'm mixed up with all this
    My alternator can't keep up, i even replaced it with another stock one that has been tested to see if i could hold me off till i found one that i wanted and it still wont keep up. Cold weather really does weird things
  10. #270
    Oct 2005
    Hou. TX
    Quote Originally Posted by sporty_drew View Post
    I've never run dual batteries so I can't say for sure.
    When you say the alternator can't keep up, do you mean the lights dim when you hit a big bass note?
    CarPC's in F-bodies
  1. 2002 Camaro Install
    By Z28CTYHNTR in forum Show off your project
    Last Post: 12-19-2006, 04:56 PM
  2. I want to install a switch
    By Froogle in forum Power Supplies
    Last Post: 04-13-2006, 11:12 PM
  3. 78 Camaro Type LT install.
    By hcker2000 in forum Show off your project
    Last Post: 12-31-2005, 08:29 PM
  4. 1998 Honda CRV Headunit-less install
    By hihidamon in forum Show off your project
    Last Post: 02-24-2005, 05:38 PM
  5. Please help install a Front End
    By Zebelkhan in forum Newbie
    Last Post: 01-31-2005, 06:40 PM
