Page 29 of 45 FirstFirst ... 192021222324252627282930313233343536373839 ... LastLast
Results 281 to 290 of 442
Thread: 1998 Camaro Install- lots of pics, rear seat delete
  1. #281
    Oct 2005
    Hou. TX
    I'm all nervous about how the cable feels. I never had time to install it on my car to test it. Let me know when you get it installed.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  2. #282
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    Quote Originally Posted by JasonWW View Post
    Ok, i'll try to get it in tomorrow. I've been busy at work with all this snow
    1998 Camaro Worklog Starting over, New setup for 2010
  3. #283
    Mar 2006
    Iowa
    I picked up a Optima Yellow Top G31 on the CA forums this afternoon
    It was between that and a Kenetik 1400, but the guy selling it was the second owner
  4. #284
    Mar 2006
    Iowa
    Well i didn't get to cable today because of class and finals are coming up
    I did find a Stinger 80 amp Relay on the oznium forums that i picked up for 14 dollars from Moss There are some great guys on there, too bad i gave up on most of my car lighting.
    Would i be better to wire this batteries run directly off the alternator opposed to the jump post on th drivers side? I'm going to do the big three at the same time so will it really make a difference? What about my ground, would i be better to run another 0/1 gauge from my front battery to the back one?
    I'm trying to figure out how much 0 gauge i need to order and loom and end rings.
    Heres what my next order will consist of for Knu Konceptz
    Set Screw Ring Terminals - 1/0
    (They are reusable)
    1/0 Gauge
    (i can't decide on whether i use silver or blue for power)
    In-Line Waterproof ANL Fuse Holder w/ Fuse
    And then from Elemental Designs i'm thinking about picking up some
    eD 0 Gauge Flex Loom
    I haven't decided on distribution blocks. I'll need two that have one 0/1 gauge input and two 4 gauge outputs. One for the power (fused) and another for ground. These will go to my front stage amps and i'll most likely run 4 gauge strait to my RE 35.1, which will only be about 3 feet.
  5. #285
    Jul 2007
    Your car is beautiful man, great job on all of your install
  6. #286
    Mar 2006
    Iowa
    Oh yea i was going to ask you about Air Ride Technology's Air Struts. Are these truly 100% bolt on to where you only need lines, valves, compressor, tank, and switches (or controller)? You were talking about leaning away from them because they weren't as performance driven as you want right? Hows their track record for a Daily Driver like me with a little v6 ? If thats a good kit for me i don't think that price is too much for a completely bolt on kit.
  7. #287
    Mar 2006
    Iowa
    Quote Originally Posted by Marty182 View Post
    Thanks alot man. Shes coming along.
  8. #288
    Oct 2005
    Hou. TX
    Quote Originally Posted by sporty_drew View Post
    You should only need one run of 0 ga from front to rear. Just ground the rear battery to a solid part of the car in back. Are you going to run an isolator? I'm not sure what your asking here for the on the plus side.
    Oh yea i was going to ask you about Air Ride Technology's Air Struts. Are these truly 100% bolt on to where you only need lines, valves, compressor, tank, and switches (or controller)? You were talking about leaning away from them because they were as performance driven as you want right? Hows their track record for a Daily Driver like me with a little v6 ? If thats a good kit for me i don't think that price is too much for a completely bolt on kit.
    Why spend $900 for the front Air Rides when for $580 you can get these in chrome?
    You just pick the top and bottom mounts you want and they should just bolt in.
    And Yes, it was the lack of performance shocks from these types of one-piece units that made me design the ones I'm putting together. I just don't like compromise. I think both the kits above will be fine as far as cruising around. If you look at the latest post in my air bag thread you'll see a video of a Magnum that swapped just the steel springs for the air springs and you'll see how much better it handles as a result. Neat stuff.
    CarPC's in F-bodies
  9. #289
    Mar 2006
    Iowa
    Very nice. Where are those at? What about rears? I need something i can just bolt in since i'm only good at the electrical side of things. And i'll check out that link (i have that page permanently open in a tab )
    On the side of my wiring issues i didn't want a ground loop by not running a line for ground.
  10. #290
    Oct 2005
    Hou. TX
    Just right click the pic and choose properties. (mods won't let us post links). It will show Suicide Doors dot com.
    The rears use the regular, cheaper bags, nothing fancy.
    You could just get those Aero Sport bags like me and slip them over your stock shocks. If money is tight. It may ride better than it does now.
    CarPC's in F-bodies
  1. 2002 Camaro Install
    By Z28CTYHNTR in forum Show off your project
    Last Post: 12-19-2006, 04:56 PM
  2. I want to install a switch
    By Froogle in forum Power Supplies
    Last Post: 04-13-2006, 11:12 PM
  3. 78 Camaro Type LT install.
    By hcker2000 in forum Show off your project
    Last Post: 12-31-2005, 08:29 PM
  4. 1998 Honda CRV Headunit-less install
    By hihidamon in forum Show off your project
    Last Post: 02-24-2005, 05:38 PM
  5. Please help install a Front End
    By Zebelkhan in forum Newbie
    Last Post: 01-31-2005, 06:40 PM
