Page 3 of 45 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 442
Thread: 1998 Camaro Install- lots of pics, rear seat delete
  1. #21
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    Sorry 56k...
    Here are pictures of the computer running in the car.
    I'm not going to post pictures of the motherboard, m2, or hard drive until i have them mounted where i want them (will hopefully be happening tomorrow or so)
    I've ordered my ai-net adapter for my alpine head unit and it'll be here Friday so i can get rid of the god awful fm modulator..
    When i was installing the computer i found that my ps2 mouse would bring the computer out of standby whether i had it set to or not I fixed that by unplugging it after the install. I have the M2-atx set for 5 seconds to standby and then never for hard off, is this what everyone normally uses? I'm wondering how long it takes to drain the battery in S3..
    1998 Camaro Worklog Starting over, New setup for 2010
  2. #22
    Mar 2006
    Iowa
    Finished cleaning out the mounting of the motherboard, psu, and hard drive. I plan to add another psu just above the sub later on. here are the pictures
  3. #23
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    looks good but ummmmmmmm I'm not sure how good of an idea it is to have a completely unsheilded computer sitting right next to that hug magnit (sub)... that may give you problesm in the future
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  4. #24
    Mar 2006
    Iowa
    I'm thinking about changing around the set up in the hatch but i can't decide what to do, I'm also thinking about running a completely separate computer for control over lights and other little things. This way i could choose to only turn that one on at night. If i did that one would want to move the amp and put it there so it's symmetrical.
  5. #25
    Oct 2005
    Hou. TX
    Hey, this is the first I'm seeing of your setup. It looks pretty cool, but I might cover part of the PC. Maybe make a Lexan box with the ugly parts painted and the rest left clear. Plus you could control the cooling over the whole PC as well.
    What do you have in the far rear? Can you use any space in there or is it all used up?
    I was using S3 for a quite a while, but the constant draining and recharging on the battery will cause it to go bad over about 6 months. I was using an Optima red top. Now if you have a yellow top you would be OK. I would try and use Hibernate with the hard off option to keep your battery in good shape.
    Check out this thread:
    http://www.mp3car.com/vbulletin/gene...s-methods.html
    I need to put your car and one other car into the big F-body thread. Is that OK with you?
    Too late! Check post #20.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  6. #26
    _
    Mar 2004
    Little Elm, Texas
    thread moved to completed!
    congrats!
    Jan Bennett
  7. #27
    Mar 2006
    Iowa
    thanks for adding mine Jasonww I'm trying to fine something else to do with the way it looks. The rest of the space is reserved for the t-tops lol. I really like my stand by so i guess I'll invest in a yellow top.
    Thanks RedGTiVR6
    Also the wire looming has been removed, but like a said above I'm trying to decided that i want to do while finishing my skin.
  8. #28
    Mar 2006
    Iowa
    Well today it hit 92* and the computer shut off and when it rebooted it said a thermal error had occurred, i guess I'll be completely redoing the rear so that the computers can both have there own enclosures that are well ventilated and monitored. I'll sketch up whats in my head tomorrow and post some pictures and see what you guys think.
  9. #29
    Mar 2006
    Iowa
    some updates
    Well I move the computer to the rear "cubby" hole
    I plan to do something like this to cover it up and seal it to try to help with the temp. I don't think it'll be plexi tho as that would look out of place. It's also going to have the cutouts for my backplate most likely.
    I also rigged up the power button to my rear hatch release button since i don't always want the pc coming on and like the control of turning it on and off when i need to.
    I want to make a beauty panel for the sub box it'll go up to the little curve in the side panels and then across the front of the box, i tried to roughly outline it in red. what to you guys think? I'd make it out of fiberglass but i would end up carpeting it and it'd look the same then.
    In the next week i plan to repaint my bezel, the piece around my gauges, vent holders, and try to mold the ac controls in the center console and paint the upper part of it. I'm going to make that beauty panel and cover in the next few days most likely.
  10. #30
    Oct 2005
    Hou. TX
    Quote Originally Posted by sporty_drew View Post
    In my opinion, if you carpeted it, it would probably look about the same so I wouldn't waste my time unless I was going to make something that would definetely improve the looks. I don't want to sound harsh, but it's your car so you can tell us to flip off and do whatever you want to.
    You mentioned fiberglass. Was that because you wanted to paint it, cover it in vinyl or because of the weight?
    It's kind of hard to make something asymetrical look good. Is there any other place you can mount your amp or are you going to get another matching amp?
    Here's something that comes to my mind. Take everything off the box then roundover the edges with about a 1/2 round over bit in a router. Then take the box and coat the outside with fiberglass. Sand it all down and then paint it.
    Or something easier, just replace the carpet with sheetmetal or even aluminum sheet. The box looks like all the sides are flat. You could take one sheet and cut the corners then fold them down. Sheetmatel can be painted or even chromed. Stainless can be polished to look like chrome. Even aluminum can be polished if you want. That would give it a big bling factor when you pop the hatch plus a second amp on the box would be easy to add.
    CarPC's in F-bodies
  1. 2002 Camaro Install
    By Z28CTYHNTR in forum Show off your project
    Last Post: 12-19-2006, 04:56 PM
  2. I want to install a switch
    By Froogle in forum Power Supplies
    Last Post: 04-13-2006, 11:12 PM
  3. 78 Camaro Type LT install.
    By hcker2000 in forum Show off your project
    Last Post: 12-31-2005, 08:29 PM
  4. 1998 Honda CRV Headunit-less install
    By hihidamon in forum Show off your project
    Last Post: 02-24-2005, 05:38 PM
  5. Please help install a Front End
    By Zebelkhan in forum Newbie
    Last Post: 01-31-2005, 06:40 PM
