Page 4 of 45 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 442
Thread: 1998 Camaro Install- lots of pics, rear seat delete
  1. #31
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    the reasoning for adding it would be to make it flow a bit more. I'm getting a 7202 or 7252 for the other side so it'll look the exact same. The reason i said fiberglass was so that i could make the whole thing one piece, but i would carpet it because i want it to just flow and not stand out. Why is it that you don't think it would make a difference by putting a cover on it?
    Another idea would be to bring the box up a bit and sink the amps into the box( maybe at angles?), i would still bring it up to the sides.
    1998 Camaro Worklog Starting over, New setup for 2010
  2. #32
    Feb 2006
    Melbourne, Australia
    Looking good there, one of the better out-of-case installations I have seen so far - quite tidy wiring, keep it up.
    Luv it
  3. #33
    Oct 2005
    Hou. TX
    Quote Originally Posted by sporty_drew View Post
    The reasoning for adding it would be to make it flow a bit more. I'm getting a 7202 or 7252 for the other side so it'll look the exact same. The reason I said fiberglass was so that I could make the whole thing one piece, but I would carpet it because I want it to just flow and not stand out. Why is it that you don't think it would make a difference by putting a cover on it?
    Getting a matching amp will go a long way as far as looks go.
    The reason I don't think a carpeted cover would make a difference is because it looks pretty good right now. It just seems almost impossible to get anything to blend into those side panels unless you mold them all together into a single piece.
    Another thought, is to turn the sub around and then build up the middle part of the box about 3"-4" so that the magnet will actually fit into it. Then you could make a one piece, flush cover with cutouts over the amps to show them off. Is that an option or do you like having the sub magnet exposed?
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  4. #34
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Actually, I kind of like the smoked plexi cover.......
    I was going to box mine and carpet, but now.......I may have to rethink that.
    Also, I notice you have a dell. I'm using a dell optiplex 260. Did you have to check the pinouts for your PSU or is it a standard 20 pin atx connection?
    Cheers
  5. #35
    Mar 2006
    Iowa
    it's a standard 20 pin.
    Well as for the whole turning the sub around, I was looking at different subs last night an I'm thinking either 2 10" G5's or 1 12" G5. I know what you mean when it comes to blending something to the side panels, they have a weird curve.
  6. #36
    Oct 2005
    Hou. TX
    How much air space is in that box? It looks like 1.2-1.5 cu ft.
    Who makes the G5?
    CarPC's in F-bodies
  7. #37
    Mar 2006
    Iowa
    The box is 1.3 Ft^3
    Boston Acoustics ~ here are the specs for both the 10's and the 12's
    Size
    10 -inch
    12 -inch
    Impedance
    4 ohms
    4 ohms
    Cone Material
    Copolymer
    Copolymer
    Surround Material
    Foam
    Foam
    Sealed Box Volume (cubic feet)
    0.5
    1
    Ported Box Volume (cubic feet)
    1.3
    2
    Port diameter (inches)
    3
    4
    Port length (inches)
    11
    14
    Free-Air
    No
    No
    Dual Voice Coil
    No
    Yes
    Sensitivity
    88.9dB
    94.3dB
    Frequency Response
    24 - 0.35k Hz
    20 - 0.35k Hz
    RMS Power Range (Watts)
    100-450
    100-450
    Peak Power Handling (Watts)
    Top Mount Depth (inches)
    6 11/16
    7 3/8
    Bottom Mount Depth (inches)
    7 5/16
    8 1/8
    Cutout Diameter or Length (inches)
    9 3/16
    11
    Vas (liters)
    29.54
    75.28
    Fs (Hz)
    34.51
    28.88
    Qts
    0.55
    0.47
    Xmax (millimeters)
    15.3
    15
    I'm really leaning towards sticking with 1 12 so i can keep the amps on the sides. if i would do the 10's i would put the sub amp in the middle and the speaker amp on the back "wall" in the t-top holder.
  8. #38
    Oct 2005
    Hou. TX
    Dang, in looking at the first post again I see you already mention the size of the box. Oh well, at least I guessed right. So both of those amps look like they can run 2 ohm stereo or 4 ohm mono. If you got the single 12" you could bridge the amp and run it 4 ohm mono for the most power. I like the single 12 idea, but the dual 10's should work well in that box too. For the 10's you'd need to get the dual 4 ohm version. Then you could wire both into a single 4 ohm load again. Is that what you were thinking?
    It looks like a single amp could power one sub really well. 450 watt amp into 450 watt speaker.
    CarPC's in F-bodies
  9. #39
    Mar 2006
    Iowa
    I was actually thinking of getting the dual 4 ohm 12 and running it at 2 ohms, just set my gain accordingly. The 9102 can run 2 ohms mono and 4 ohms stereo. i could get the dual 2 ohm, but I've never like the wiring configurations for dual 2 lol.
  10. #40
    Oct 2005
    Hou. TX
    I don't think they make the G5 subs in dual 2 ohm. I thinks it's either single 4 ohm or dual 4 ohm. The 9102 is a mono class D amp. It will run mono 2 ohm or higher, but not stereo.
    It's true that you could get a single 12" in the dual 4 ohm style and then wire the coils in parallel for a mono 2 ohm load. Are you sure you want a class D amp, though? They kind of just flop the cone around with no real control over it. I always stick to class AB for good control and sound quality.
    CarPC's in F-bodies
  1. 2002 Camaro Install
    By Z28CTYHNTR in forum Show off your project
    Last Post: 12-19-2006, 04:56 PM
  2. I want to install a switch
    By Froogle in forum Power Supplies
    Last Post: 04-13-2006, 11:12 PM
  3. 78 Camaro Type LT install.
    By hcker2000 in forum Show off your project
    Last Post: 12-31-2005, 08:29 PM
  4. 1998 Honda CRV Headunit-less install
    By hihidamon in forum Show off your project
    Last Post: 02-24-2005, 05:38 PM
  5. Please help install a Front End
    By Zebelkhan in forum Newbie
    Last Post: 01-31-2005, 06:40 PM
