Page 5 of 45 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 442
Thread: 1998 Camaro Install- lots of pics, rear seat delete
  1. #41
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    Quote Originally Posted by JasonWW View Post
    It's true that you could get a single 12" in the dual 4 ohm style and then wire the coils in parallel for a mono 2 ohm load. Are you sure you want a class D amp, though? They kind of just flop the cone around with no real control over it. I always stick to class AB for good control and sound quality.
    I think i'll get the dual 4 ohm. I didn't know that with the class d you lost sound quality compared to an ab. i knew they wasted more energy. I'm going to read up on that more.
    I've also decided that I'm tired of my onboard sound. I'm going to be getting a pci sound card and I'm going to look at equalizer software. if i don't find anything i like I'll get a sound processor.
    1998 Camaro Worklog Starting over, New setup for 2010
  2. #42
    Mar 2006
    Iowa
    Quote Originally Posted by mrbean_phillip View Post
    Looking good there, one of the better out-of-case installations I have seen so far - quite tidy wiring, keep it up.
    Luv it
    Thanks a lot, it's a work in progress
  3. #43
    Oct 2005
    Hou. TX
    Quote Originally Posted by sporty_drew View Post
    A good PCI card to get is the Chaintech AV-710. It is really cheap at under $25 and channels 7 and 8 use a very nice high end Wolfson DAC. The 2 channel sound quality is really nice. It also is good at hibernating and suspending.
    As for using a software EQ, check out this link.
    http://www.mp3car.com/vbulletin/car-...ns-tuning.html
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  4. #44
    Mar 2006
    Iowa
    I'll look into that card. what is a good output level to look into for a card? I've been reading up on RedGTiVR6's card he's making and Durwood's project. I've also looked at that link to the free software a few times but i don't understand exactly what i need and how it works with processing the sound after leaving winamp, i definitely need to do some searching on that.
  5. #45
    Oct 2005
    Hou. TX
    The output level isn't of any real concern. If your going straight from the analog out to an amp you would adjust the amp gains to give you the volume you need. What stereo components are you running right now? Does it go from the PC straight to the amps?
    Red, BTW is a girl. Her name's Jan.
    I don't fully understand all that software EQ stuff either. I use a Alpine H700 and it does all the x-over, EQ and time alignment seperate from the PC. I kind of like it that way.
    CarPC's in F-bodies
  6. #46
    Mar 2006
    Iowa
    I don't fully understand all that software EQ stuff either. I use a Alpine H700 and it does all the x-over, EQ and time alignment separate from the PC. I kind of like it that way.
    Thanks for telling me about Red...
    I'm going from my pc to my alpine 9860 then back to my amp, I'm getting one for my front speakers soon. And I'm not running a rear stage. I was thinking about getting either a H700 or H701 for my alpine. I was also considering getting a stand alone processor like the one that kenwood or pioneer offer. I'm leaning towards just a processor since i don't need the cd player anyways.
    I'm also trying to sell my L7 so i can get the G5, so hopefully in the next week or so. Jason could you better explain the whole ab compared to d class amp?
    I was also thinking about what everyone thought it would look like if i sunk my amps in the sub box and put plexi over them with the camaro logo etched in them. If I did that i would have exactly 1 ft^3 but the 1.3 ft^3 might be better and look a bit better.
  7. #47
    Oct 2005
    Hou. TX
    The 9860 is a good unit. If you can afford a H701 then I would get that. It's a serious piece of hardware that I don't see you outgrowing for many, many years down the road. You can run an digital optical signal from the radio up front to the H701 in the rear. It makes for a very clean signal. I'm running the digital signal from my sound card to the H701 and it's a notch above the analog signal. The flexability is great. If you ever ditch your CD player you can run the Chaintech sound card straight to the H701 using it's SPDIF output. As a bonus the H701 controller should fit in the dash space you made for the faceplate.
    I'm not familiar with the new 07 Pioneer and Kenwood processors, but last years models weren't even close in comparison to the Alpine H701.
    The class differences are easy to explain, but the sound differences aren't. If you picture a sine wave it has a smooth flowing curve to it. This is similar to the control the AB amps have over the subwoofer. It's under control at all times. With a D or BD class amp it gains it's efficiency by cycling the signal on and off very quickly. So instead of a smooth sine wave curve it looks more like a series of steps or stairs. It cycles like this to try and duplicate a sine wave, but it really can't. So when the volume is really cranking and the sub is really moving the signal is full on and full off to push the sub back and forth. This is fine for most bass heads who just want it loud without sucking up too much alternator juice.
    I listen to a variety of types of music, not just bass stuff. I like the AB amps because they can make a good sub blend in with the front speakers and create a more realistic listening experience. The AB amps have full control over the subs movement at all times.
    As far as arrainging things I'd like to see a drawing of some kind just to make sure I know what your describing. Are you wanting to sink the amps down 3" and then mount the new G5 cone up and then build the center area up higher so the magnet fits? I think it would look strange. I would want the amps and the sub closer to being on the same plane. I don't really see the point of lowering the amps. It would be easier to leave them higher and then make a cover to fit over the top. Or you could mount the newer G5 cone down, like the L7 is. You could make a cover over the amps and then leave a round hole around the sub for the magnet to stick out and to let the bass get out. Then put plexi covers over the amps.
    There's really a bunch of ways to do it. It will really be up to what you think looks best.
    CarPC's in F-bodies
  8. #48
    Mar 2006
    Iowa
    Ok i understand the amps.
    I really wish that there was another processor out there that was close to par with the alpines but not 500. I want to get a processor and scrap the CD Player, I wouldn't get full control over a processor with it anyways. how are the alpines that were before the 700 i think there was a 510. i know there were a couple alpine processors i was watching on ebay that went for around 180- 200. i'm going to do a bit of searching and see if i can find one thats a little closer to my price range.
    With the bow i was talking about mounting the G5 the same as the L7 and then sink the amps, but as i thought more about it at work tonight i decided that i didn't like the idea and that I'll pry just leave them as is and make that beauty panel i talked about earlier.
    I'm going to do a little researching and I'll post what i find. I'll also stay away from the pioneers and kenwoods, is there any other brand i can look at?
    edit: i found the H510 here are the specs
    http://caraudiosecurity.com/shop/pro...ts_id/425.html
    and here is one on ebay
    http://cgi.ebay.com/Alpine-PXA-H510-...QQcmdZViewItem
    I didn't know that the H710's were so cheap now only 376 shipped
    http://cgi.ebay.com/Brand-New-Alpine...QQcmdZViewItem
    Can you control the volume from the C701? I don't want to have to tap the screen to change the volume when i get rid of the CD player.
  9. #49
    Mar 2006
    Iowa
    Made my cover up today. I'm thinking I'm going to add a plexi window in and etch Krypton Customs in it. On with the pictures
    I completely forgot to get a shot of a normal standing prospective, I'll get that up later tonight.
  10. #50
    Oct 2005
    Hou. TX
    The 510 is completely different. It's not what you'd call a high end piece, plus the EQ is parametric only which can be pretty tricky to set up. I'm not saying it's bad, just that I never considered it for my system. My previous processor was a Rockford EPX2 with the 28 band EQ card installed.
    http://cgi.ebay.com/Rockford-Fosgate...QQcmdZViewItem
    The 510 would have been a step down for me. In fact you might look at the EPX2 as they are going pretty cheap. They take analog only for the input, but are good units.
    Typically the H701 go for $500 for the brain, but $375 is a pretty low price. If you don't use the headunit to control it you would need the RUX controller which is about $150-$200 and it has a dedicated volume knob.
    CarPC's in F-bodies
  1. 2002 Camaro Install
    By Z28CTYHNTR in forum Show off your project
    Last Post: 12-19-2006, 04:56 PM
  2. I want to install a switch
    By Froogle in forum Power Supplies
    Last Post: 04-13-2006, 11:12 PM
  3. 78 Camaro Type LT install.
    By hcker2000 in forum Show off your project
    Last Post: 12-31-2005, 08:29 PM
  4. 1998 Honda CRV Headunit-less install
    By hihidamon in forum Show off your project
    Last Post: 02-24-2005, 05:38 PM
  5. Please help install a Front End
    By Zebelkhan in forum Newbie
    Last Post: 01-31-2005, 06:40 PM
