Page 6 of 8 FirstFirst 12345678 LastLast
Results 51 to 60 of 72
Thread: 2006 Acura TL OEM Navi Touchscreen Integration
  1. #51
    Dec 2004
    Quote Originally Posted by gnhuntin View Post
    Here is a link to the manual for a 1270 (Scan Do 800) it is for a Black Box AC095A but they are one in the same.
    http://www.blackbox.co.uk/technical/...A%20Manual.pdf
    The pinouts for the RGB composite 9 pin connector on the rear of the scan do 800 are:
    1. Ground
    3. Red
    4. Green
    5. Blue
    8. Composite Sync
    Awesome - thanks so much. So did you use a DB15 connector into the Scan Do? Why couldn't I just use the standard VGA 15 pin out of the laptop into the VGA port on the Scan Do?
  2. #52
    Apr 2008
    Quote Originally Posted by lebshiff21 View Post
    The VGA input from a regular pc (it is opposite for a mac) on the scan do is the HD 15 (2 rows - 15 pins) the standard DB 15 (3 rows - 15 pins) is for pass through output to a Standard VGA Display ie (say you are doing a presentation using your keyboard and mouse sitting at a desk you could use your regular monitor and everyone else would be watching a big screen tv). If you also need this cable. PM me and I will send you a picture with the pinouts or you can order one for $31. It is CSI part#101257 cable. You can purchase it through Graybar or your local Anixter office (www.anixter.com).
  3. #53
    Dec 2004
    So I got it all hooked up, but something is wrong.
    When I tap into the RGBs wires for the LCD, I get red blue and green, but the white seems wrong. I've tried playing w/ the brightness, gamma, and contrast, but it just seems like it's not there.
  4. #54
    Apr 2008
    Are you usin the scan do 800? If so hit the test button and look at the color bars and compare it to your laptop. It could be the blue and green are reversed.
  5. #55
    Dec 2004
    I just tried it - When I hit the test button once - I get nothing, just a blue screen. When I hit it a second time, I get a green screen w/ a black bar on the left.
    edit: just checked that manual you linked:
    4.2 Using the Front-Panel Controls
    TEST BUTTON: This button will force your Converter to generate one of two
    test signals on its COMPOSITE and S-VIDEO outputs. (These test signals are
    not available on the RGBS output.) When you press this button once, the
    indicator LED on the button will light up and the Converter will output a
    “color bar” signal. When you press this button a second time, its LED will stay
    lit, but the Converter will now output a “grayscale ramp.” When you press this
    button a third time, the LED will go off and the Converter will resume
    outputting images received from your computer.
  6. #56
    Apr 2008
    I see. Can you power the scan do inside and use the rca composite connection to a television and see if the color bars look ok on the tv. Split the problem to see if it is the scan do, wiring to Nav Screen or something else?
  7. #57
    Dec 2004
    If I use the composite it works OK, sort of blurry, but colors are correct. So it's not the Scan Do. Must be the cable I made between the Scan Do RGBs out to the screen wires in my trunk for the LCD. I'll play with it tonight and see if I've just got something backwards. Thanks for your help.
    So in the trunk there's a serial cable spliced into the RGBs out from the back of the nav unit. There's only 4 wires (RBGs obv.) I verified they're correct via an Acura wiring diagram. My question is - where should the ground out of the Scan Do go (pin 1)?
  8. #58
    Apr 2008
    I'm not sure for yours, but in my car (mazda) I had a ground. Try checking the wires with a DVM and see if one of the wires reads 0 ohm to the chasis and try that.
  9. #59
    Dec 2004
    And for the bare wire that's inside the serial cable? I don't really know where to terminate that inside the metal hood I have...
  10. #60
    Apr 2008
    I used pin 1 from the rgb connector to my ground. I did not connect the shield on the end that I made up.
  1. 2006 Acura RSX Type-S Project
    By FaKk2 in forum Worklogs
    Last Post: 07-29-2007, 12:06 AM
  2. Acura TL 2004 touchscreen install
    By moahdib in forum Fabrication
    Last Post: 10-22-2006, 11:00 AM
  3. Any successful integration of S&T 2006?
    By xbi0s in forum Centrafuse
    Last Post: 07-26-2006, 06:11 PM
  4. Acura OEM touchscreen?! ANYONE KNOW?!
    By EggrollXpress61 in forum LCD/Display
    Last Post: 07-24-2004, 02:13 PM
  5. Acura TL 2004 LCD
    By TLer in forum Car Audio
    Last Post: 07-06-2004, 02:00 PM
