Page 7 of 8 FirstFirst 12345678 LastLast
Results 61 to 70 of 72
Thread: 2006 Acura TL OEM Navi Touchscreen Integration
  1. #61
    Dec 2004
    Looks like it might have been the ground wire from the Scan Do! I extended the ground out of pin 1 to a ground on the chassis and the screen looked perfect.
  2. #62
    Apr 2008
    Glad you got it figured out.
  3. #63
    Nov 2007
    i am stuck in designing a switch... pls help
    whats the best way(less components and sodering needed) to build a switch to switch between the stock unit touch screen input & computer usb input? any chance of a schematics showing how it works ...
  4. #64
    Mar 2009
    wow this is by far the most amazing custom pc i have ever seen!!!! that looks awesome in the acura...20 years or so this will prob be standard....goo job!!!! and i am having problems just trying to hook up a usb to the nav (like the new 09 tsx) so i can play music from a flash drive (usb) any reccomendations???
  5. #65
    Mar 2009
    Newport News, Viginia
    can you be able to help me
  6. #66
    Mar 2009
    you did a great job dude
  7. #67
    Nov 2009
    the setup in the picture is it exactly right where the wires come FROM and go TO on the relay? and what kind of switch is used on the Positive part of the relay like in the picture? what type of board to use any pc board from radio shack? the wires that connect the scan converter to the 04 acura tl harness what colors are they does anyone know? Thanks again
  8. #68
    Aze
    Aze is offline
    Dec 2005
    Roskilde, Denmark
    WOW. Very nice job. Thumbs up...
    I'm just wondering...How have you made the control of the switching through a button "on screen"?
  9. #69
    Dec 2007
    really amazing work, met152!
    I have mitsubishi galant with OEM 7'' navigation touchsreen... seems like now I know how to use the stock touch glass with carpc. thanks a lot
    I googled for scan do 800/1024 converters and noticed they costed a lot...
    how do you think could I use a device like the foolowing one?
    http://www.converters.tv/manuals/vga...ter_40_135.pdf
    thank you
  10. #70
    May 2009
    bump from the dead but can you even by this scan do 800/1024 converter any more?? I dont see much about it anywhere, this is all I could find. Is there another solution these days?
    http://www.boxedpreview.com/html/ScanDo800.asp
  1. 2006 Acura RSX Type-S Project
    By FaKk2 in forum Worklogs
    Last Post: 07-28-2007, 11:06 PM
  2. Acura TL 2004 touchscreen install
    By moahdib in forum Fabrication
    Last Post: 10-22-2006, 10:00 AM
  3. Any successful integration of S&T 2006?
    By xbi0s in forum Centrafuse
    Last Post: 07-26-2006, 05:11 PM
  4. Acura OEM touchscreen?! ANYONE KNOW?!
    By EggrollXpress61 in forum LCD/Display
    Last Post: 07-24-2004, 01:13 PM
  5. Acura TL 2004 LCD
    By TLer in forum Car Audio
    Last Post: 07-06-2004, 01:00 PM
