+ Reply to Thread
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: 1990 9C1 Caprice
    Newbie OKflyboy's Avatar
    Feb 2005
    Tulsa Area, OK
    Thumbs up 1990 9C1 Caprice
    [edit] Finished!! Here's some before and after shots:
    From this:
    To this:
    From this:
    To this:
    [/edit]
    Well, I recently lost my job... Rather than sulk about it I've decided to take the time to do the things that I have been meaning to do to my car. You can also follow along with the other things I'm doing to the car here @ my ImpalaSSforum forum thread.
    Here's the Car (At least how it was this summer):
    And the interior:
    The carPC is going to be slightly ghetto. I've got an old e-machines AMD 1700xp tower that I'll be installing.
    Specs
    CPU: AMD Athlon XP Processor 1700+
    Operating System: Windows XP Home Edition
    Memory: 640MB DDR
    Hard Drive:80GB WD Scorpio Laptop HDD
    Optical Drive: HP DVD/CD-RW Drive; 3.5" (Pulled from my 'new' Home PC)
    Video: S3 ProSavage8 integrated
    Sound: AC '97 Audio (on board)
    Case Dimensions: 7.25"W x 14.125"H x 16"D
    Interface:
    Keyboard: Dreamgear Mini-key
    Monitor: Xenarc 700ts
    I'm not using a special case (I was hoping to find a decent small desktop-style Micro-ATX case but I've been repeatedly outbid on Ebay so I give up...), and no DC-DC power supply. I've got a 175w (350w peak) inverter I'll be powering it with. I've set the inverter on a switch and I have the BIOS set to power-on whenever it receives power so I'll fire it up with the switch and shut it down manually through XP.
    I already had the PC, it was my home PC until the PS died. I wasn't able to track it down to the PS until after we had already bought another PC to replace it, so this one gets carPC duty now. I bought an 80gb laptop drive for $80 from Best Buy, I paid $14 for the Mini-Key Keyboard, $20 (I think) for the inverter and I paid $200 for the Xenarc. So all-in-all this will be a fairly low $$$ install.
    To get the sound from the PC to my ears I plan on going to a 1/2 DIN Equalizer then to amped 6x9s and subs. The EQ has a master volume knob on it so I plan to configure the PC to be on full volume all the time and I'll control volume from the EQ. For radio I have a portable AM/FM walkman that'll plug into the EQ's aux plug.
    Here it is in my office for bench testing and prep (Minus the Xenarc which has not arrived yet):
    More to follow...
    I am an American soldier. If you will not stand behind me, feel free to stand in front of me.
    Feb 2005
    Tulsa Area, OK
    the new interior shot;
    CarPC installation starts tomorrow...
    Feb 2005
    Tulsa Area, OK
    Well, I got my Xenarc yesterday but it snowed and it was damn cold, so I didn't get a lot of work done.
    Here's the Xenarc running Frodo (what can I say, I can't get RoadRunner to run properly and Frodo is easy to configure...):
    This afternoon I got started on the console that will house the monitor, gauges and equalizer. It's 1/2" MDF
    Here it is during a test fit:
    again:
    This is just the rough-up. After I figure out where everything's going to go and cut all the holes I'll go over it with bondo to smooth it and cover all my misdrills.
    I have two ideas for paint.
    1) (definitely the easiest of the two) I was thinking of just painting it with textured black paint.
    2) I have some pine laying around. I thought about making a new top piece out of the pine, then painting everything but the pine a blue-ish gray (or whatever the closest match I can find to the interior color) and staining the pine a mohogany (or whatever the closest match is to the interior woodgrain)
    Feb 2005
    Tulsa Area, OK
    Today I cut all the correct holes and put it through a trial fit. This is with the carPC sitting in the back seat just to get a feel how everything's going to work.
    Music:
    And DVD:
    As you can see I've got the Xenarc, the gauges and the switches all mounted. This switch on the left will control the inverter's relay and the switch on the right will control the audio equipment's relay. The current stereo will be replace with a 1/2 DIN Equalizer, and I may put a laptop DVD-ROM in a USB 2.0 enclosure there as well...
    I've now hit it with some bondo. I'm waiting for it to cure a bit then its time for sanding...
    Feb 2006
    Vancouver, BC
    sweet. Good choice in dvd's too. Full Metal Alchemist is awesome.
    Feb 2005
    Tulsa Area, OK
    Quote Originally Posted by guizai View Post
    Yeah, I've got all the episodes and now the movie on DVD.
    This weekend was my reserve weekend so I didn't get anything done until tonight.
    Here's two picture of the painted console empty:
    And after the gauges, switches and Xenarc were installed:
    It's textured flat black. I used black silicone to keep everything in place, the glare in the 2nd pic is from the still wet silicone. Also the paint was still a little wet while I was mounting everything so I got some fingerprints in the paint. After it cures completely I'll sand it down in those spots and hit it again (after covering the xenarc etc with painters masking tape)
    Hopefully permanent mounting will begin tomorrow...
    Jan 2007
    New Jersey
    Not bad at all. I'm looking at doing the same type of install for my 99 Altima. Was it at all difficult wiring the turn on switch for the inverter? Also, do you have any pics of where you placed the tower in the car?
    Feb 2005
    Tulsa Area, OK
    Quote Originally Posted by lexdiamond20 View Post
    I haven't done the final mounting or wiring yet, but I'll be leaving the inverter in the "on" position and using a relay to turn power to it on or off. I'll post my progress as it happens.
    Feb 2005
    Tulsa Area, OK
    Teaser pic as I test for final fit:
    Jan 2007
    New Jersey
    Quote Originally Posted by OKflyboy View Post
    Godd idea. Also, will the pc automatically start-up when the inverter turns on? I assume there will be some type of current giving the signal. Or will you have a seperate switch to turn on the pc after your inverter is powered up?
    Thank in advance.
+ Reply to Thread
  1. 1990 widebody Toyota Celsior
    By Blipman in forum Worklogs
    Last Post: 11-20-2006, 10:18 PM
  2. 1990 VW Beetle
    By EvilAngel in forum Worklogs
    Last Post: 04-10-2006, 01:35 AM
  3. WANTED - Toyota Supra 1990 Roof bars
    By tracysupra in forum Classified Archive
    Last Post: 11-01-2005, 07:22 PM
  4. 1990 Cherokee carputer install
    By MAXXMODDER in forum Show off your project
    Last Post: 05-20-2004, 08:11 AM
  5. 1990 Celica GT - New Install
    By HereFishyFishy in forum Show off your project
    Last Post: 09-08-2003, 01:15 AM
