Results 21 to 30 of 36
Thread: Suburban - Custom console carputer - W/Pics
  1. #21
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Are you running power from the battery? Where did you pull the wire through the firewall?
    TruckinMP3
    Read the FAQ!
  2. #22
    Oct 2006
    any updates today?
  3. #23
    Feb 2007
    Quote Originally Posted by TruckinMP3 View Post
    Yes I am running power from the battery to my relay and then to my switch that lights up my 12v distribution block. I pulled my wire through a hole that was in my firewall just to the right of my brake booster area.
    Rc
  4. #24
    Feb 2007
    Quote Originally Posted by spoonraker View Post
    any updates today?
    Yep, I am sorting the photos now, will post in a few minutes.
    Rc
  5. #25
    Feb 2007
    Quote Originally Posted by Rafster View Post
    Nice work!
    I'm starting to build something kinda like this for my car...
    What is the largest drink you can comfortably put in those cup holders?
    Rafster
    I tested it with a 64oz big gulp type cup and also I tested it with the Great Big One from Dunkin Donuts. They both fit great so I was sold.
    Rc
  6. #26
    Feb 2007
    Okay update time:
    I was able to get my relay and power distribution set up over the weekend. I also mounted the power supply and motherboard in the console.
    The power supply fit very nicely against the back wall. This allows all of my connections ATX/Molex/IDE to have very short cables without alot of messy wires running all over the place. I also wired my 2 cooling fans to 5v power from the floppy molex rather than 12v, they were just spinning way too fast for in the car. Now they move alot slower but still move plenty of airflow.
    Motherboard installed and grounding block now installed.
    Hard drive mounted underneath, I was looking for something to secure the meadia card reader from moving if somebody pushed on it too hard. I ended up gluing a wood strip just behind the rear of the unit so that if you push in it will hit the wood block and not move.
    This is the view from the rear, this are will be under the heater area below the dash. You can see my main power and ground quick connects in this picture. This will make it easy for me to move the entire unit to another vehicle if I need to.
    Another rear shot. This picture is without the end cap attached. When the end cap is attached you will only be able to see a 1/4 inch gap lengthwise with the wires running out of it.
    I got the lilliput in the mail on Friday and had a chance to open it over the weekend. Nice little monitor for the money IMHO. Touch screen drivers went in without issue and seem to work great after a quick calibration.
    Lilliput rear view
    Front view showing the Power/VGA/Audio/RCA pigtails.
    The lilliput mount from the factory before I cut it up.
    Okay this is where I am going to mount my LCD. This is my cupholder and it fits in the dash and extends outwards about 8 inches to expose the cupholder.
    The modified lilliput mount. I cut it to size for the cup holder. I am going to use the adhesive from the factory as well as drill 4 screw to hold it tight. I am not real worried about the holes in the cup holder facia because I have seen them on ebay for about $40.00 to replace if I need to. I do plan on getting an extra mount for the other vehicle so I can just pop the monitor off of one mount and on another.
    Here is the mount on the face of the cup holder.
    Here is the LCD mounted on the cup holder. Notice the 4 screws I drilled to be sure that the monitor was tight and would not give way.
    Thats all of the pictures I have for now.
    The unit is currently installed in the vehicle and it is running great. I am using RR with the Digital FX skin and it is just amazing. I am not sure how I lived without a carputer for so long.
    My Verizon vx6700 with EVDO service works great for High Speed Internet on the road. I am using S & T 2006 with RR and the DigFX skin, it integrates very nicely. The touch screen is working as expected but I find myself using my stylus alot instead of my finger. All in all I am quite happy with the carputer so far. I do need to do some more tweaking and finish up mounting the inverter under the seat and routing some cables so that they look a little neater. I will take more pics of the actual unit in the truck with the screen mounted and front end running as soon as it stops snowing/sleeting/raining outside.
    Cheers
    Rc
  7. #27
    xgc
    xgc is offline
    Aug 2006
    florida
    Hi Rcracerx, looking good! Also, I'm pretty sure I have a couple of the lilli stands if you want them. I will look in the parts bin later.
  8. #28
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    looking good man, where did you get your carpet from? how well does it match?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  9. #29
    Feb 2007
    Quote Originally Posted by scott_fx View Post
    Hey thanks bud,
    Actually I got the carpet at Walmart in the auto section. I am color blind as a bat but my wife tells me it sorta matches the darker area of the dash but not the carpet. She said in the pictures the difference is much more obvious then looking at it in person.
    Rc
  10. #30
    Feb 2007
    Quote Originally Posted by xgc View Post
    Thanks.
    Hey that would be great man, let me know. I was gonna look for one that would accept the small block that stays in the LCD. If you have a factory one like that I would definitley be interested.
    Rc
  1. Need Help with my custom console to house 8" Lilli
    By Gordinho80 in forum Fabrication
    Last Post: 12-03-2004, 04:04 PM
  2. FS / Carputer in lexan custom case.
    By NDelMoore in forum Classified Archive
    Last Post: 11-28-2004, 11:49 PM
  3. 2004 Trailblazer Custom Console
    By pberrett in forum Fabrication
    Last Post: 10-21-2004, 01:51 PM
  4. Carputer / center seat console?
    By aethernaut in forum General Hardware Discussion
    Last Post: 10-25-2003, 11:10 PM
