Suburban - Custom console carputer - W/Pics
My goal is to build a carputer in my 99 Chevy Suburban 2500 that is totally self contained. I need to be able to take the entire unit out of the Suburban and put it into both my 06 Chevy 1500 and also when I am camping to bring it inside the trailer and use it as my PC.
After a little thinking I decided I needed to build a center console to hold everything and give me the ability to move the unit from vehicle to vehicle.
Hardware:
MB - ECS 761GX-M754 w/Semperon M3000+ 754
RAM - 2X512 DDR400= 1G total
PS - INWIN|IW-P240F1-0 240W
Inverter - 750W
DVD - DVD_BURN LITE-ON|LH-18A1P-185 BK
GPS - M.S. S&T 2007 w/supplied GPS
LCD - Lilliput 7" Touch screen LCD VGA
HD - 250Gig Seagate IDE
Sound - Onboard
TV - WinTV PCI Tuner Card
RCam - Not sure of brand yet
Key/Mouse - Mini USB KB and MS Wireless mouse
Internet - VX6700 USB (EVDO) or Cingualr 3G PCMCIA (I have both not sure what I am going to use yet)
Software:
Windows XP Pro SP2
MS S&T 2007
RR Front end (Not 100% SURE ON FRT END YET)
Center console build:
http://mysite.verizon.net/cenley/car...20(Medium).JPG
The vehicle for the proposed install a 1999 Chevy Suburban 2500 - Primary use is as a Tow vehicle for a 34 foor travel trailer. Not a daily driver.
The old solution was my Laptop on the mount that I bought from Ebay, not a terrible solution just not what I was looking for.
This is the area that I will be installing my custom console.
I am using 5/8 MDF for my console construction along with 5/8 Pine for the lid because I was not sure how the MDF would hold up when I routed the edges and screwed in the hinges.
The basic box is being built. I mocked up the dimensions with cardboard
I added 3 metal brackets at the bottom of the console to hold a 1/4 piece of plywood that will act as a mother board tray. It will be secured with Velcro strips. I will be able to take the entire board out of the console without removing the actual console. For maint reasons mostly. I also figured that it would be best to get the computer components sitting up higher than the carpet under the console.
Here it is with the tray installed in the bottom along with the lid hinges installed.
Here is a view of the front of the console. The smaller area in the front sildes under some HVAC work under the dash. The small piece of wood laying on top of that area will be secured with velcro and will be the area that all connections will enter the console. I will be able to lift the small piece of wood off and make all connections and then just lay it back down to hide all the wires.
One of my biggest complaints of the truck is the terrible cup holder placement. The cupholder is built just under dash vent and pulls out towards you and does a very poor job of holding cups. I decided that while I was doing this I wanted to make myself some cup holders that work for "ME". I picked up a few different cheapo cup holders at Pep Boys and Walmart. Finally I decided on the $6.00 Walmart "wedge" style cup holders. After a little bit of dremmel work and some cutting I had some cup holders. :)
Cup holders and lid installed
Lid opens and allows access to the system if needed
Test fit and deciding on carpet color.
Partially covered in carpet
100% covered. The area you see in this picture between the carpeted area and non carpeted area is where all my wiring will come into the console. The small top piece of wood there is attached with velcro and pops right off if I need to get to the connections.
More Pics in next thread - RC
