Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: 2002 Acura TL-S
  1. #11
    Mar 2007
    Earth
    Very nice and clean install. I might attempt to do something like that with my TL.
  2. #12
    Apr 2007
    very awesome. i have the same car but lack the fabrication skills. obviously a tech noob but is there anywhere i can purchase what you fabricated for the screen? does anyone make that on this forum for 2nd gen tl's that i can buy off? is that what a metra kit is?
  3. #13
    Apr 2007
    any advice on how to fuse the metra kit with the headrest mount? sounds sorta difficult? any quick or in depth pointers would be more than appreciated
  4. #14
    Jan 2003
    I'm an Electrical Engineer....so the tech stuff comes easy for me too. I never worked with bondo, but conceptually I know how it works and how I should use it.
    First and far most...bondo is a FILLER not an EPOXY or ADHESIVE. I used Metra kit and dremeled out the center until I could slide the headrest mount through. You want to use some sort of plastic type of epoxy to attach the headrest mount to the metra kit. Use bondo to over fill in the gap. Sand it down. Repeat until you are happy (I must have repeated this process about 20 times....you could practice on scrap material). If you want to temporary hold things together, I use "multi-temp" glue sticks....about $2 from walmart. It;s strongs...bond well to plastics. Get a wide range of sand paper, from 100 to 1200 to save you time from sanding too much.
    It's not too hard once you start it. I'll try to get pics up within a couple day.
  5. #15
    Jan 2003
  6. #16
    Jan 2003
    I decided to add a "theft-deterrent" mod. I bought a Acura Radio off ebay for $35. Removed the face...glued all the buttons together...now I have a OEM HU face-plate to conceal the screen
  7. #17
    Mar 2007
    Earth
    That's a great "theft-deterrent" mod! Nice set up BTW.
  8. #18
    Apr 2007
    great set up. this will be my refernce when i copy it! what is in your cupholder
  9. #19
    Jan 2003
    Quote Originally Posted by bangumandoo View Post
    The thing inside my cupholder is the 1) main power rocker switch [when i don't want auto-on with ignition to the M2-ATX] 2)Computer Reset 3)Computer Power Switch 4) Monitor On/Off | Switch video input 5) Eject DVD Drive 6) Extra button for future use
  10. #20
    Apr 2007
    awesome. i thought the metra kit doesnt cover the area where your cd changer tray used to be. how did you fill that space?
  1. Acura TL owners - LCD help
    By FiSKARZ in forum LCD/Display
    Last Post: 08-03-2010, 05:07 PM
  2. Weird 04' Acura TL Alpine OEM Nav video feed?
    By EggrollXpress61 in forum Newbie
    Last Post: 01-27-2007, 09:11 PM
  3. Replies: 2
    Last Post: 11-26-2006, 03:41 PM
  4. help on kenwood kvt-911 and aftermarket HU 00 Acura TL
    By KiDWiTh2kTL in forum LCD/Display
    Last Post: 01-12-2006, 11:26 PM
  5. Acura TL 2004 LCD
    By TLer in forum Car Audio
    Last Post: 07-06-2004, 02:00 PM
