Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 67
Thread: Mazda MP3 Project part II
  1. #51
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    I cleaned up some of the wiring this weekend, re-did some grounds, and re-routed what I could.
    This will be my next purchase for my car computer system:
    It is the Phoenix SOHO PCI Conference Card. The only problem is that I have one PCI slot, and it is being used, but there is a solution! There is a thread where forum member Salmizar figured out how to power the PCI card externally, and was able to achieve awesome echo-canceling results for car phone conferencing. Just needs 5V that you can get from the 5V rail on your power supply, or you can hack up a USB cable to get the power instead. They even tell how to make an external enclosure for it!! It is basically used as a pass-through for sound, so that the card can execute hardware echo cancellation.
    You can find the info here: http://forums.fluxmedia.net/general-...enix-soho.html
    My Car: 2001 Mazda MP3
    My OLD Carputer project: Here
    Completion Progress Bar: [**********100%]
    Current build! Here
    Completion Progress Bar: [*********99%]
  2. #52
    Jul 2003
    2010 Updates: Re-did my motherboard mounting, and will now be using a SATA drive. Also picked up a Preassembled Black Double Din LCD Frame with 7" Lilliput 629GL-70NP/C/T.
    Current build! Here
  3. #53
    Jul 2003
    Crappy mobile phone pic of the new screen in place:
    Current build! Here
  4. #54
    Variable Bitrate we87's Avatar
    Nov 2005
    Dallas, TX
    What An Update?! Looks good...
    What is the behind the scenes of your volume knob? Hacked up ps/2 mouse? Usb phidget?
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
    Everything is in the car and working.
    I painted the cilpboard mount and it looks good.
    Shutdown/Startup is working excellent!
    View My Progress Here
  5. #55
    Jul 2003
    I love the new screen. It is bright, and reads good even in direct sunlight!! The knob is for boost control for the turbo system.
    Current build! Here
  6. #56
    Constant Bitrate golfguy's Avatar
    Nov 2006
    Fort Worth, TX
    I was considering that screen for the Z. Has it worked pretty good for you?
    Any day is a good day for golf.
    Mazdaspeed6 Carputer Progress: Gone
    (Check Speedy's Install)
    Speedy was traded for a 2004 350z - Install complete except for permanent screen installation.
  7. #57
    Jul 2003
    Works perfectly! Bright and readable in direct sunlight as well... All you need is the proper Metra radio dash install kit, and you are good to go!
    Current build! Here
  8. #58
    Jul 2003
    It seems that my old Deluo GPS receiver died, so I replaced it with a Globalsat BU-353.
    Current build! Here
  9. #59
    Jul 2003
    OK, this Globalsat BU-353 is AWESOME! I locked 6 satellites instantly in the garage, with the garage door down!!!
    Current build! Here
  10. #60
    Jul 2003
    The latest upgrades to my Car PC:
    Current build! Here
  1. Commerical MP3 Hardware
    By MooN in forum General Hardware Discussion
    Last Post: 09-26-2005, 05:22 AM
  2. Mazda introduces MP3 car
    By RaZor in forum General MP3Car Discussion
    Last Post: 03-04-2002, 09:31 AM
  3. Pictures of my Lifted Project Jeep with MP3
    By surfer6262 in forum General Hardware Discussion
    Last Post: 01-25-2002, 10:28 PM
  4. Car MP3 Costs
    By mp3designer in forum General MP3Car Discussion
    Last Post: 01-25-2001, 07:19 AM
  5. Do you guyz know this cool machine?
    By Ginger in forum General Hardware Discussion
    Last Post: 04-19-2000, 12:38 PM
