Results 1 to 2 of 2
Thread: Volume turns itself down
    Jan 2002
    For some reason after i turn off the system and restart it, it turns the volume down 50% somtimes on the master sometimes on the wave, sometimes both. What is going on? Also, winamp freezes if i run it on startup. Im also running the comport plugin, WinME, and the LCD plugin.
    "A4 Quattro. Rocket Science."
    Jul 2002
    Boston, MA
    Does the PC get shutdown properly, or does it just get powered off with the ignition?
    If it just gets powered down, Windows may not save your settings. In this case, do a proper shutdown and that should solve it.
    Also, do you have real player installed? I've had this cause problems on tons of PC's. If you do, open real player and do two things: 1) Disable smart center all together. 2) Before closing real player turn the volume up in RP all the way.
    Otherwise I'm out of suggestions right now...
