Results 1 to 10 of 10
Thread: Start application
    Variable Bitrate nemo1's Avatar
    Jun 2006
    Start application
    Does anyone know how to start an application, for example gps proxy when windows start? I search and tried placing a shortcut in the startup folder but it only starts the app, it is not started. What I mean is if we place a winamp shortcut in startup folder it will start winamp but it does not play any songs. Have to put a play list in and songs will be played. How can I do this for GPS proxy?
    Mar 2006
    Colorado, but Canadian!
    autoit perhaps.
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2006
    I'll try....Thanks
    Mar 2006
    Usually autoit can help, but in some cases it cant. In that case, you might need to right an application using API calls and put that alond with the gps program in the startup folder...
    Jun 2006
    I have autoit installed but don't know how to program.....Any hint I could start with? BTW what is API?
    Mar 2006
    API is the system windows uses for everything. When you right click some program in the task bar, that is a command. When you click close from the menu that is a command.
    So you need to find the handle of the window, which is a 32bit int (obviously only on 32bit systems), and then the command like "SendMessage" from the user32.dll, and then the argument of "Push button".
    Can get really complicated.
    Jun 2006
    It will be easier using only autoit?
    Mar 2006
    Quote Originally Posted by nemo1 View Post
    Easier yes.
    There are quite a few autoit scripts floating around the forum, and you might be able to learn by example. Basically if there is a keyboard shortcut to do what you want it to do, then really easy. If there is a menu item, then easier. If not, then you are pretty much SOL.
    Jun 2006
    Thanks for all the reply and info...I'll try it out
    Jun 2006
    Quote Originally Posted by 2k1Toaster View Post
    Easier yes.
    Tried it and it worked.....just like you said its easy. Only 2 lines.
    Anyone interested can copy here....auto start for GPS Proxy
    Attached Files Attached Files
  1. How do Mapmonkey autostart on RR start
    By xpluis in forum Road Runner
    Last Post: 04-08-2007, 01:52 AM
  2. Replies: 0
    Last Post: 09-23-2006, 09:38 PM
  3. Notifying child application of Hibernation wakeup
    By mullaly in forum Road Runner
    Last Post: 04-24-2006, 04:44 AM
  4. Car won't start after carputer install
    By UnsanePyro in forum General MP3Car Discussion
    Last Post: 07-24-2005, 05:44 PM
  5. How to embbed any Application in RR ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 01:35 PM
