Page 10 of 18 FirstFirst 123456789101112131415161718 LastLast
Results 91 to 100 of 180
Thread: HQCT software development
  1. #91
    Nov 2006
    Cambridge, UK
    HQCT-eA support
    Quote Originally Posted by Putput View Post
    To keep you guys (and girls) informed, there hasn't been much progress the last few days. I'm doing my best to get the new version ready but HQCT_eA support is consuming a lot more time then I expected in the first place and I also have a lot of personal stuff to deal with the last few weeks. Perhaps I can release the beta without proper eA support? (Sorry Paul) What should I do?
    Regards,
    Putput
    Hi Putput,
    Don't let me get in the way of a beta for others. I've been busy too in the last two weeks (including a rather hastily-arranged trip to the US) and my own hacked-version of Diogenes program is working quite well (I'm saving the AF list to disk and this gives v.fast AF re-sync even if there is no AF data being received). However, once your DLL is available with eA support I'll do the integration with RR and swicth to CPCTuner.
    Paul
  2. #92
    Low Bitrate Pishaa's Avatar
    Oct 2005
    Quote Originally Posted by Pishaa View Post
    I have noticed that when the taskbar was on top of cpctuner so I was able to see both clocks, there was a one hour difference. I've checked my watch clock and the system clock was correct.
    I'll check if the problem is with the RDS time or with displaying the system time or maybe both and report it to you.
    /Me.
    Ok, my conclusion is that if the clock ends with a small dot '.' (pc time), the clock is correct.
    If the clock does not ends with a small dot '.' (RDS time), the clock is one hour early, I think because of daylight saving.
    Can anyone else can confirm this? (I must admit I could find only one station with RDS time in my area)
    And another thing:
    Sound/reception quality has been degraded since previous version: the stereo indicator keeps swithing on and off all the time, with the previous everything and the same station is OK. Is there any config switch related to this problem?
    thanks,
    /Me.
  3. #93
    FLAC TheLlama's Avatar
    Jul 2004
    All over the world
    I'm too lazy to dig through this and all the other crazy forums focused on the HQCT.
    Where is the current 'baseline' driver or whatever? I need to backport the new RDS features back into the Linux driver.
    (oh yeah, I'm back...)
  4. #94
    Constant Bitrate Putput's Avatar
    Sep 2005
    Belgium
    Quote Originally Posted by TheLlama View Post
    Aren't we all ...
    You can find all my HQCT software here, but I'm still working on a number of things like News, Traffic and AF. (Having lots of troubles in finding time for software development lately, my kid was in hospital for a week) In the latest beta (still containes a number of bugs and no eA support, guess that's why they call it a beta ) you can find an overview of received EON and AF data, look in the settings screen.
    Glad to have you back!
    Regards,
    Putput
  5. #95
    Jul 2004
    All over the world
    Aren't we all ...
    Regards,
    Putput
    Great. I will look into your sources. I'm not too worried about News, Traffic, etc.. those aren't really used in my area. Self-centered... maybe, illogical... I wouldn't think so.
  6. #96
    Newbie DeLorean Dave's Avatar
    Jul 2005
    Long Island, NY
    Luc, we all hope your son is feeling much better.
    Anyone here know about how the HQCT actually gets tuned? I mean there seems to be the possiblity of more than one parameter invovled in the tuning in of a station. This I why I think this... When using the CPCTuner program...
    At one point I had two buttons programmed for 98.3 MHz FM, one was very fuzzy and the other sounded great.
    On the latest version, ver.48 I found that in order to get 770KHz AM I have to enter 760. All the frequencies are shifted up by 10 KHz, but when I was playing around I was able to get a button that says 770 and actually get 770 as well as a button that says 760 while it tunes 770 and all it still is tuning in stations 10KHz higher than the display , execpt on that one 770 button.
    I am confused???
    1981 DeLorean DMC-12
    VIA SP13000, Xenarc 700TSV, 100GB hdd, 1GB ram, WinXP, BU335 GPS, iNav 3.0, Griffin PowerMate, M2-ATX, HQCT-AM/FM USB Radio (Software by Luc)
    PMD-1208 USB Data Acquisition
    Flux Capacitor
    Kensington USB 2.0 BT Dongle just dangling
  7. #97
    Jul 2004
    All over the world
    It's really confusing. The radio gives back a several data points. To tune to a frequency one must interpolate between these data points and then do a bunch of arithmetic. When I first wrote my driver, the Windows HQCT software did not properly use these values. Therefore, the software didn't work well on every HQCT unit. I thought this was fixed a while back (on the Windows side) so it shouldn't be an issue.
    I don't know anything about CPCTuner.
    But, as you can see, the radio needs more than a simple frequency in order to tune. People are trying to make a library for the HQCT because of this complexity.
  8. #98
    Sep 2005
    Belgium
    Back in business (Slowly .. )
    Hello there ,
    Greetings from Belgium again (for as long as it exists )!
    Just want to let you know that a new version is ready for testing. Yes I know, I've made some promises in the past but I will keep this one. You can find it on my download page. Don't be too hard on me if not everything is working as it should, I haven't had much time for testing lately. But please let me know if you encounter any problems/bugs. This version completely supports all HQCT_eA features.
    Greetz,
    Putput
    PS When you start this version make sure that you open the settings window and press the default button and then the OK button. This will override my HQCT module parameters with your HQCT module parameters. This is important because each tuner has a different set of parameters and when these are wrong reception could be bad. I will change this in the next release so that it will automatically detect and replace faulty parameters.
  9. #99
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Stockholm, Sweden
    Sorry for troubling you with my simple questions.
    I have a HQCT-e module and was just trying to get it going.
    I downloaded the CPCSuite into c:\CPCSuite and tried to run rrhqct.exe
    I got "CPTTuner could not connect to HQCT module!"
    "Error: HQCT module not found on USB bus! "
    Have I missed something? I tried to find something on http://direct.xtronic.be/products/hq...io/hqct-e.html
    but that site does not work properly.
    My module operates on single 12V supply doesn't it?
    Is there a driver I have to install?
    BR, B-O Swing
  10. #100
    Sep 2005
    Belgium
    Quote Originally Posted by bes51659 View Post
    BR, B-O Swing
    Hi bes51659,
    No need for a driver, the HQCT modules are HID devices that have native Windows support (like USB mouse, keyboard etc).
    As far as I know (I'm not one of the hardware developers, you will have to ask Diogenes to be sure) the -e version needs only 12V.
    Check (see picture) in your Computer Management that there is a device 'Car radio' in the HID devices list. If its not there you will have to check your wiring again. Also a simple trick is to disconnect power or the USB cable from the device and Windows should then sound ding-dong, when you reconnect it a few seconds later it should sound dong-ding. Then you know that the module is connected.
    Once you are shure that the wiring is ok and Windows recognises the module the software should work.
    Have you downloaded the latest build from my website? If so try an older version like build 42, I changed some stuff so that CPCTuner can detect what HQCT module type is connected in the latest build. It could be that there is still a bug in the connection routines that check the module type info, the -e version is the only module that I don't have here for test purposes. Perhaps someone else can confirm if the -e version works with the latest build or not?
    CPCTuner doesn't support Vista for the moment, so when you are trying to use Vista this could also be the cause of the problem.
    Success!
  1. CarPal Bluetooth Module & Digimoto Software....A Very Good Combo..
    By jmciver in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-16-2006, 05:08 PM
  2. Replies: 2
    Last Post: 11-15-2005, 02:38 PM
  3. MSDXM.OCX - Why oh why don't you fix that NOW?!
    By Zippy1970 in forum Media Engine
    Last Post: 02-28-2005, 05:36 PM
  4. Software solution for gLCD-based car-mp3
    By Novgorod in forum Software & Software Development
    Last Post: 07-01-2004, 08:59 PM
  5. My numpad controlled custom MP3Car software - need your opinions
    By PorscheMP3 in forum Software & Software Development
    Last Post: 04-11-2002, 11:30 AM
