Page 14 of 18 FirstFirst ... 456789101112131415161718 LastLast
Results 131 to 140 of 180
Thread: HQCT software development
  1. #131
    Feb 2007
    Nr Aylesbury, UK
    The Silabs stick is nice and cheap and I can use it in the house when the -eA is working, the plan was to sell the Genesis 4 channel amp once I was happy with the -eA's performance as well.
  2. #132
    Constant Bitrate Putput's Avatar
    Sep 2005
    Belgium
    Decription of RR interface in latest build:
    Hello,
    Here's the code from CPCTuner that handles the RR interface commands:
    Code:
       // RR_V holds value after ';' when the command is numeric
       // RR_C holds RR command
       // RR_C1 holds value after ';' when the command is alfa-numeric
       // HQCTuner is the HQCT object
       // SendToRR is a function that sends data to RR
       case RRCommand of
          tune   :
             begin
                // Check if we have to switch between AM/FM for new frequency
                if (RR_V < 6700) then
                begin
                   // New AM freq from rr
                   if HQCTuner.FMBand then
                      HQCTuner.FMBand := false;
                   if RR_V <> HQCTuner.FrequencyAM then
                      HQCTuner.FrequencyAM := RR_V;
                end;
                if (RR_V >= 6700) then
                begin
                   if not HQCTuner.FMBand then
                      HQCTuner.FMBand := true;
                   if RR_V <> HQCTuner.FrequencyFM then
                      HQCTuner.FrequencyFM := RR_V;
                end;
             end;
          seekup : HQCTuner.ScanStations(ScanUp,   false);
          seekdn : HQCTuner.ScanStations(ScanDown, false);
          mute   : HQCTuner.Mute         := not HQCTuner.Mute;
          step   : HQCTuner.FMStepOffset := RR_V;
          source :
             begin
                case TRRSource(ansiindextext(RR_C, RRSource)) of
                   // TunerSrc, CDSrc, PhoneSrc, NaviSrc
                   radio : HQCTuner.SoundSource := TunerSrc;
                   aux1  : HQCTuner.SoundSource := CDSrc;
                   aux2  : HQCTuner.SoundSource := AUXSrc;
                   nav   : HQCTuner.SoundSource := NaviSrc;
                   phone : HQCTuner.SoundSource := PhoneSrc;
                   else
                end;
             end;
          setvol      : HQCTuner.Volume := RR_V;
          setbass     : HQCTuner.Bass   := RR_V;
          settreble   : HQCTuner.Treble := RR_V;
          setmute     : if (RR_V > 0) then HQCTuner.Mute := true else HQCTuner.Mute := false;
          switchinput :
             begin
                if copy(w_s, Pos(';', w_s) + 1, 2) = 'on' then
                begin
                   // Save current source
                   CurrentSource := HQCTuner.SoundSource;
                   // switch to new source
                   if LeftStr(w_s, 3) = 'dio' then
                   else
                      if LeftStr(w_s, 3) = 'ux1' then
                      else
                         if LeftStr(w_s, 3) = 'ux2' then
                         else
                            if LeftStr(w_s, 3) = 'nav' then
                            else
                               if LeftStr(w_s, 3) = 'one' then
                end
                else
                   // switch to previous source
                   HQCTuner.SoundSource := CurrentSource;
             end;
          rvol    : SendToRR('rvol;'    + IntToStr(HQCTuner.Volume));
          rtreble : SendToRR('rtreble;' + IntToStr(HQCTuner.Treble));
          rbass   : SendToRR('rbass;'   + IntToStr(HQCTuner.Bass));
          else
       end;
    It's possible to control the following CPCTuner functions:
    - switch (frequency AM/FM)
    - seek (a station up)
    - seek (a station down)
    - mute (toggles)
    - step (step is used when CPCTuner starts seek, be carefull, no value check yet, use 10 for 0.1Mhz in FM; 20 for 0.2Mhz)
    - source (switch between audio sources)
    - setvol (change volume between 0 and 68)
    - settreble (change treble between 0 and 7)
    - setbass (change bass between 0 and 7)
    - setmute (0=unmute, 1=mute)
    - switchinput (switch between audio sources, special)
    - rvol (read current volume)
    - rtreble (read current treble)
    - rbass (read current bass)
    A lot of these functions are specified more in detail in this post from PaulKaye.
    So if you need to change the volume in the -eA version, use the setvol command with a value between 0 and 68, or the source command to change between radio/CD/phone ... So all you have to do is add a slider or button to RR and send the correct message.
    Have fun!
  3. #133
    Feb 2007
    Nr Aylesbury, UK
    Luc,
    I'm very new to RR, are you saying that a suitably modified RR skin is ready to control the -eA via CPCTuner?
    All the tuner functions worked, but I couldn't swap sources nor control volumes or tone.
    Cheers
    Carl
  4. #134
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Stockholm, Sweden
    Hi Luc!
    I downloaded the new 1.1.1.50. Small change in log file. http://web.comhem.se/bengt-olof.swing/20071130Log.txt
    I also tried the new dll and runned it with vb example. I did <start>, end then pressed <FM>.
    Do you get any clues from this?
    Cheers, B-O
    Ps.
    One little ide. If the logfile contains version info there will be no question what sw that was acctually run at the time.
    Ds.
  5. #135
    Sep 2005
    Belgium
    Quote Originally Posted by Aspectcarl View Post
    Luc,
    Carl
    Yes, I modified the interface (Windows messages) so that the -eA version can be controlled via RR. Of course RR needs to be modified for this. The description of the messages can be found in my previous post. I also have a little test program I use (see attachment), its very simple. Start the test program, then start CPCTuner and you can control CPCTuner by typing messages in the text box and push enter or the Send button. The listbox shows messages that are sent to RR. You can use this tool to help test the commands that need to be send to CPCTuner.
    Luc,
    Carl
    You mean via RR then? This is normal, RR doens't send the right commands yet to CPCTuner to change volume, source and or tone.
    I will send an email to PaulKaye tomorrow and ask him if he has made any progress on his -eA interface for RR. After all he asked me to change the interface.
    Success!
    Attached Files Attached Files
  6. #136
    Sep 2005
    Belgium
    Quote Originally Posted by bes51659 View Post
    Hi Luc!
    Cheers, B-O
    Ps.
    Ds.
    Updated (CPCTuner and DLL) again, hopefully this is the one.
    I'll add the version info in the logfile this weekend.
    Cheers,
    Luc
  7. #137
    Sep 2005
    Stockholm, Sweden
    Sorry, P. Not quite yet....
    00:20:14:325 INF: Tuner - CPCTuner version 1.1.1.50.
    00:20:14:325 INF: Tuner - Communication thread created succesfully.
    00:20:14:325 INF: Tuner - USB object created successfully.
    00:20:14:335 INF: Tuner - Windows message tuner thread: 12
    00:20:34:514 INF: Tuner - Windows message tuner thread: 28
    00:20:34:774 INF: Tuner - Windows message tuner thread: 28
    00:20:47:623 INF: Tuner - Windows message tuner thread: 2
    00:20:47:633 INF: Tuner - Windows message tuner thread: 130
    "Could not connect. Timeout error"
  8. #138
    Sep 2005
    Stockholm, Sweden
    Bump
    Not pushing, Luc. Its soon xmas.
    But just in case you think my HQCT-e is working all of a sudden, its not :-) I'm just working on some other stuff. (Mostly An 8051 system for controlling power to LCD, USB hubs, PC, rearview camera and communicating on BMW IBus)
    Just hoping I'm still on your todo list.
    If not before then, Merry X-mas!
  9. #139
    Sep 2005
    Belgium
    Bump
    Hi B,
    Just a stupid question that you probably already gave the answer for but I'm not sure. Does the software from Diogenes work with your module?
    Solution hopefully before X-mas
  10. #140
    Sep 2005
    Stockholm, Sweden
    Hi Luc
    I tried The RRHQCT original ver 2.0 from your site before and I did not get any errors. But I did not have a proper antenna to try it out completely and have not heard any sound.
    So in order not give a stupid question a stupid answer I will try again :-)
    Hold on.
  1. CarPal Bluetooth Module & Digimoto Software....A Very Good Combo..
    By jmciver in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-16-2006, 04:08 PM
  2. Replies: 2
    Last Post: 11-15-2005, 01:38 PM
  3. MSDXM.OCX - Why oh why don't you fix that NOW?!
    By Zippy1970 in forum Media Engine
    Last Post: 02-28-2005, 04:36 PM
  4. Software solution for gLCD-based car-mp3
    By Novgorod in forum Software & Software Development
    Last Post: 07-01-2004, 07:59 PM
  5. My numpad controlled custom MP3Car software - need your opinions
    By PorscheMP3 in forum Software & Software Development
    Last Post: 04-11-2002, 10:30 AM
