Putput:
CPCTuner does not restore the last station when resuming from hibernation, all I get is static (quite irritating IMHO) and so I'm forced to select a station..
Also adding volume up/down button to the left/right of the volume slider would make CPCTuner more TS friendly.
/Me.
LinkBack URL
About LinkBacks
and not have to wait for my frontend to be ready I inserted 1 parameter in the registry for each frontend application that is default set to 'stand alone', meaning that when started CPCTuner doesn't have to look for a server to respond to and can work as a standalone program. If you decide for this reason (or any other) not to work with CPCTuner anymore
you can delete the CPCTuner.exe files and the registry key HKEY_LOCAL_MACHINE\SOFTWARE\CPCSuite from your registry to get completely rid of it. On the other hand, if you are a programmer working on your frontend you can ask me to hand over the tcpip socket protocol that I developed so yo can control cpctuner via sockets. This way it would be possible to use CPCTuner on 1 pc and control it from another pc using ip sockets over network.
