Thanks put - will post it there
Printable View
Luc,
It looks like progress is being made!
My existing antenna circuit interfaces fine with the serial port. I hope +/- 0.5ma is not too much of a load for the port. It is such a pleasure not to have to activate another program each time I use the HQCT, just to raise or lower the antenna.
Now my antenna responds directly to your CPCtuner software! :laser:
Fantastic work!
To keep you guys (and girls) informed, there hasn't been much progress the last few days. I'm doing my best to get the new version ready but HQCT_eA support is consuming a lot more time then I expected in the first place and I also have a lot of personal stuff to deal with the last few weeks. Perhaps I can release the beta without proper eA support? (Sorry Paul) What should I do?
Regards,
Putput
yeah releasing a beta would be good! so i can start implementing AF and get helped with the hibernation problem!
gosh, i wish i could just connect the hqct through the comport, that would be so much more easy and stabil.
Sorry Kosti have not looked into forum for awhile so missed your post.
I have a MB with Realtek ALC880 HD audio so finally settled on the HQCTe to match a good amp that will do it justice (if I can find one) instead of going down the eA route. It was also appealing to get the HQCTe inside my Zoom2 case instead of external setup plus I am a bit worried that it is still early days for eA support.
I ordered HQCTe early last week so should arrive soon...I am in Brisvagas so it would have been hard to organise a 2X shipment with you.
Hello,
The beta can be found on my website. Look for: "BETA!!! CPCTuner complete ZIP file, Version 1.0.1.48" under Latest build.
Putput
Strange, the clock uses standard Windows calls for local PC time when no RDS time info is received, visible with a small dot '.' at the end of the clock display. When RDS time info is received the clock shows the received station time and the dot dissapears. Maybe a silly question but have you checked your PC clock? Or does the problem only occur when RDS time info is received?
Thanks,
Putput
Hi there,
(Hi putput)
when i have my clock settings , hh:mm:ss (am/pm), the cpctuner clock is like this (........).
so, i change the win clock settings to HH:mm:ss (24/ with out am/pm) and the cpctuner it's ok.
thanks,
John
I have noticed that when the taskbar was on top of cpctuner so I was able to see both clocks, there was a one hour difference. I've checked my watch clock and the system clock was correct.
I'll check if the problem is with the RDS time or with displaying the system time or maybe both and report it to you.
/Me.
