Page 1 of 18 1234567891011 ... LastLast
Results 1 to 10 of 180
Thread: HQCT software development
    Constant Bitrate Putput's Avatar
    Sep 2005
    Belgium
    Lightbulb HQCT software development
    Hello,
    To make it easier for all people who are desperately seeking in numerous threads to find HQCT software, let's have our very own thread!
    After finding several posts in different threads about the subject I decided to make this thread to collect all info about HQCT software.
    This is what is available right now: (to my knowledge of course )
    The original RRHQCT from Datalex/XTronic at http://www.XTronic.be
    FMode’s FMRadioHal at http://www.mvci-systems.de/FMRadioHAL.zip
    My own CPCTuner and HQCT.DLL at http://users.telenet.be/cpc
    Also Radiator at http://flesko.cz/radiator.htm supports HQCT if you use my HQCT.DLL as a plug-in.
    Frontends that have native support for HQCT:
    - Centrafuse from release 1.12 on
    - RoadRunner release ???
    - There seems to be a plug-in for Streetdeck but I'm not sure about this, no idea about native support
    - Linux ?
    - Mac ?
    - Others … (I know that others will follow ...)
    If you want your site/software added to this list, go ahead and start posting, I will try to keep this first post up to date as soon as possible.
    Best regards,
    Putput
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    PM the lama, I know he developed a linux kernel module for HQCT. Great idea for a thread also! Im currently using your build 43 software and it seems to be the best windows based solution.
    Sep 2005
    Aylesbury, UK
    I am currently working on an implementation of the HQCT into my carpc software, and plan to release that version within the next 2 weeks.
    Its based on putput's DLL, which saves me a lot of hassle!
    but does anyone have an overview of all the registers and their function?
    there are some functions in cpctuner which are not in the DLL, like news, AF and i cant seem to get on to the AM band
    Sep 2005
    Belgium
    Quote Originally Posted by mischka76 View Post
    Thanks!
    I've added a text file to my website, here's a direct link.
    You are correct, version 1.0.0.17 doesn't have all CPCTuner functions yet and News is still 'under construction' while AF still contains a bug. I'm still working on that.
    About the DLL, perhaps you can give me some advice. Would it be easier to work if the DLL sends for example Windows messages to create events? Another possibility is that the DLL opens an ip port as a server where your app, as a client can connect to? Interfacing this way makes it possible to work event based on the DLL's client side. What would you prefer?
    The AM function should work, do you have the same problem with CPCTuner? What values are you entering in the integer value for HQCTSetAMFrequency? Frequencies should be between 520 and 1720.
    Regards,
    Putput
    Sep 2005
    Aylesbury, UK
    as far as i can see from your testapp, 4 times per second a string of 128 bytes is read from the hqct with all kinds of data in it, like RDS text and frequencies. thats what I meant with "registers"
    apart from the fact it occasionally brings down my vb6 environment, the dll works as a charm for me. do you have an ETA for news/af etc?
    by the way: do other radio's like silabs and dru-100 work in the same way, that a number of bytes is being read/write from the usb channel?
    as for AM, i just switched to AM with hqctswitchband and then stepped up/down. i can see when switching that the frequency changes to 1100 but cant change it.
    Sep 2005
    Belgium
    Sorry, misunderstanding, I added the info to the text file on my website.
    It has something to do with compatibility issues between Delphi and VB6. This version (build 17) works better with the VB environment then build 16 but it's not yet fully compatible. But the most important thing is that it works perfectly with the compiled VB file.
    No sorry, it is still a hobby and I need to find the time for it. AF is almost finished, but because both traffic and news need AF to work it has to be in this order => AF, then news/traffic. I hope to get it finished before the end of this month.
    To be honest, I have no idea. I thought that the Silabs thing works in a similar way but it also sends music via USB so no analog input is required. Don't know how the D-Link thing works.
    I downloaded the example from my website (just to make sure that I uploaded the correct version ) and it works without a problem with both FM and AM. Try to insert a numeric value between 520 and 1720 and push enter instead of the 'Set freq' button in the example.
    Let me know if it works or not.
    Putput
    Jul 2005
    Motorcity
    Blog Entries
    1
    Hey Putput, Im running your software and I am still getting the splash screen with the rrhqct.exe
    Im not sure how to append the /nosplash switch and still have rr launch it.
    Any suggestions?
    Build 43 is working good for me. RDS info is much better, it does not blink anymore. Great work.
    Sep 2005
    Aylesbury, UK
    ah, for me it's a hobby too! But I want to have a working version ready before 19th of may, there is a car-pc gathering here in the UK. stuff like news and AF i'll just add later. I also want to integrate the silabs as the popularity of it seems to be very high. if i had heard about the silabs earlier i wouldnt have bought the hqct. ah well, fate has it!
    I am quite far now.. i can tune, read RDS, change the volume, change seek sensitivity, add stations to memory and select them from memory. I'll have a frequency readout on top of my screen that's red or green depending of stereo or not.
    tomorrow i will try once more to get this AM to work. I managed to change the frequency but cant get a read-out of the current AM frequency.
    thanks for the register information. correct me if i'm wrong, but there is no register for volume?
    Sep 2005
    Belgium
    Hi Mischka76,
    Look again at the hqctdll_calls.txt file, I added the calls which are related to Radiator, with these calls you can read parameters like volume, treble, bass and more. The names are different but you can use the calls parallel to the others, there is no need to use/install Radiator to use them.
    All Radiator functions are implemented (from build 16) and have been tested with Radiator and the Radiator test program that comes with the SDK examples.
    Hope that this can help you a little to get a working version before the 19th.
    Putput
    Sep 2005
    Belgium
    Hi blk02si,
    Quote Originally Posted by blk02si View Post
    Did you copy the file from this post into the rr\hqct folder, it should work? Don't have the sources with me right now, need to check it tonight. I'l let you know
    Any suggestions?
    The easiest way is to start CPCTuner with a shortcut on your desktop, place shortcut, click with right mouse button choose properties and add /Nosplash to the target command line. That should do the trick when you start up CPCTuner directly. (See image)
    Putput
  1. CarPal Bluetooth Module & Digimoto Software....A Very Good Combo..
    By jmciver in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-16-2006, 05:08 PM
  2. Replies: 2
    Last Post: 11-15-2005, 02:38 PM
  3. MSDXM.OCX - Why oh why don't you fix that NOW?!
    By Zippy1970 in forum Media Engine
    Last Post: 02-28-2005, 05:36 PM
  4. Software solution for gLCD-based car-mp3
    By Novgorod in forum Software & Software Development
    Last Post: 07-01-2004, 08:59 PM
  5. My numpad controlled custom MP3Car software - need your opinions
    By PorscheMP3 in forum Software & Software Development
    Last Post: 04-11-2002, 11:30 AM
