Page 1 of 14 1234567891011 ... LastLast
Results 1 to 10 of 131
Thread: DS-ATX software interface
    Jan 2004
    Hello people, i'm currently building for myself a graphical interfce for my newly purchased dsatx and i was wondering if anyone else would be interested in using it. I m no expert when it comes to this type of stuff so bare with me until i get it done and over with. If there is interest for it i ll release it for everyone to use and integrate.
    So far my stand alone version, based on flash/apollo looks like in the image i attached. I will be adding another page to the interface for displaying the real time stats the power supply is providing.
    Any feedback is more than welcomed
    Cheers
    Alex
    Jul 2004
    Irvine, Cal
    good work...looking forward to this
    _
    Mar 2004
    Little Elm, Texas
    same here. If I could control my brain stem through a GUI it would make it that much better IMO.
    Jan Bennett
    Nov 2005
    Looks great!
    Perhaps also add the units used for each variable (eg: 1 = 10mV), or if you are already doing the math via your code, perhaps just the range that it will accept.
    I would love to have 'Time till shutdown' available as a tag that I can view within roadrunner.
    Cant wait till you release this.
    Jan 2004
    Thanks for the feedback people,
    this thing is really flash based so i could export it to swf and let other people integrate it with their frontends, unfortunatelly i don t know anything about integration and don t have enough time on my hands to learn.
    This is going to be geared twords people that want to monitor their dsatx continuously, so yes, a count down timer will be shown, together with temperature and voltages i guess.
    There is one more feature that is the reason behind me building this app, which is a possibility to delay the shutdown but this requieres a small firmware modification by jeff. Take this scenario for instance, i get home, the wireless network connects and starts syncronizing, i turn the engine off, the app senses that and presents me with a menu: shutdown now, delay shutdown with 15 minutes, delay s/d with 30 minutes, i press the appropiate button, lock the car and go home knowing it will get to sync and shut down.
    The drawback so far for my app is that it requieres a serial to tcp/ip software converter. There is a free java version of this available, but it ain t all that stable. Anyone have any other solution for this?
    I could use some projector software for this, but i don t know any free one with comm port access
    /edit: comfoolery seems to be the best bet for rs232 to tcp/ip conversion. If anyone has the 1.0 version without the nag screen please let me know
    Jan 2004
    OK,
    I will try and upload a working version of this(no real time nice looking monitor yet, and no setting through point and click but through typing, yet)
    What you need:
    adobe apollo runtime
    http://labs.adobe.com/downloads/apolloruntime.html
    and serial server or comfoolery installed and set up for the com port on which your dsatx resides.
    you can download the test from here:
    http://www.tzapu.com/up/cpc.zip
    very important, you need to rename the file from cpc.zip to cpc.air so it gets installed
    p.s you need to pres the (I) button to cycle through screens
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    It would be nice if it just flash base (I'm not sure if it can do that).
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Jan 2004
    i can make the apollo part just flash based, basically a swf that can be run, for people to embed, but until there is someone that actually wants to give it a try, it s easier for me to test it like this.
    p.s. it will still need comfoolery or something quivalent
    if anyone wants to give it a try, give me the size you want the flash in and whatever else you require
    Nov 2005
    What do you think about writing this as a windows service?
    I currently run AmpCtrl (it runs as a windows service) and all it does it turn my amps on when windows loads, and off before windows shutsdown. This completely stops the turn on/off pops. Only bad thing is that AmpCtrl uses my only DB-9 serial port. (Yes, I know you can use USB->serial adapters)
    If this app were a windows service, then it could could tell the DS-ATX when to turn on the AMP-ON pin on the DS-atx board. That would remove the need for AmpCtrl, and then also allow you to have an awesome GUI control for the DS-ATX.
    Jeff (zootjeff - the DS-ATX maker) might also be interested in helping, as this would give his product a huge increase in features, as you would now be able to implement a LOT of features in software to control the current DS-ATX state and timers,.
    Id also like to get my DS-Atx using USB. Either via a serial->USB adapter, or a different MAXim chip (if there is that kinda thing).
    Peace
    Jan 2004
    Hello,
    Unfortuantelly I can't make it as a windows service because it's written in actionscript and would requier some porting to some proper programming language which i don t have the time to do. The good side is I have a working flash only version right now(+comfoolery) so it can be included in any frontend and be active once the frontend loads.
    The whole pourpose of this when i started it was that I needed some kind of interface that when the power was cut(ACC off) from the power source would let me choose the time before complete shutdown, so if i m in a gas station i can choose 10 minutes, if i m going inside my house i can choose to turn it off in 1 min or leave it 30 mins for the computer to wifi sync. Unfortuantelly the ds-atx does not currently have an interface for programatically setting the count down timer after it s started so this is where i need Jeff, if he s willing to do the modifications. I wrote him an email on his site but must of got cought in spam or something as i didn t get a reply if he could or couldn t do this. Also, as far as i know the ds-atx doesn t let you turn the aux on or off as you want but i m sure jeff could add that too. I will post some requiered modifications for jeff to look at soon enough and will pm hiom about this thread to see if it s possible or not.
    Iceman, there is an usb interface for the ds-atx, mp3car and digitalww have it, search for brainstem. You could build your own though.
    Cheers
    Alex
  1. Skinnable OBD software
    By kocke in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-16-2007, 12:08 AM
  2. CarPal Bluetooth Module & Digimoto Software....A Very Good Combo..
    By jmciver in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-16-2006, 05:08 PM
  3. my OBD II Software
    Last Post: 04-06-2005, 03:53 PM
  4. Virtual CD changer software interface?
    By potatohead in forum Software & Software Development
    Last Post: 07-24-2003, 01:04 PM
  5. Whats the best software for user interface?
    By dudah85 in forum Software & Software Development
    Last Post: 06-03-2001, 12:42 PM
