I'm afraid but I really don't understand....
Where can I get the sdk...
find a line in the destinator.inf file that looks like this
//::CT_HOR,MAINSCREEN_PLAN_BTN,1005,,0x4200000b,1,53 2,81,66,1,6,0xFF,100,0
and change it ot look like this
this will permit the menu button to show on the map
The road is long but we are getting there.
See my car and donate for spinning logos at www.ildena.it/carpc
Thank you, i really need help.
in your first post, you have 11 buttons enabled (one under power and sat)
I only can get 10 : Waiting for GPS Signal still missing !
In Pn version most informations are given with this one.
Have a try in my car with reduced version of centrafuse. spx sounds are not readable but old Wav from PN works.
Skin/All/Destinator.inf
Hide and show buttons by adding/removing the // in front of the line.
Use the '::CT_HOR,' section if you use a landscape screen size i.e. 800*600 else use the '::CT_VERT, ' section.
Don't disable the Status bar or you get a crash when dragging the map.
Can I check - is this using the PN version thats available with Destiplus ? Has any one created a decent skin off the back of what ever one has said in this thread ?
Terran
Laidback; that looks really good.
what version is this??
It's the latest version?
More tips...
View Menu/Icons /Skin/All/Destinator.inf
Set Toolbar size /Skin/All/Menu.ini > ToolbarHeight
Set Toolbar size (e.g. for GoTo Address) /Skin/All/Screen.ini >ToolbarButtonHeight
Set List Slider width (e.g. To left of Addresses) /Skin/All/Screen.ini >ListSliderWidth
Set Keyboard height /Skin/All/Screen.ini >OpenKeyboardHeight
Set 'Near' menu buttons height /Skin/All/Screen.ini >ActionMenuButtonHeight (Horizontal)
Change 3D Colors /Skin/All/View3dDesc.inf
interesting.. i dont think i have the latest
i think mines is 5..
I had a problem with D6 :
As you can see i can't get the statusbar visible:
It's because actual version of destinator 6 is different from yours.
Now, i found the good one and get same result as Laidback in first page.
