Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 50
Thread: Convertibility Destinator PN - 6
  1. #31
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Yep, I was just testing your theory myself. The newer version doesn't show the Status Bar and the offending file is DestCore.dll.....wonder what they changed
  2. #32
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    yep.. Centrafu$$ 1.13 &1.14 has a destinator version which is "bad" for us that is..it won't show the status bar..use v1.12 and older..or use the destcore.dll from v.1.12..
    it works niiice.
    EDIT: older than 1.12 it uses PN... so just use 1.12
  3. #33
    May 2005
    Derbyshire, UK
    Quote Originally Posted by Laidback View Post
    It's the latest version?
    More tips...
    View Menu/Icons /Skin/All/Destinator.inf
    Set Toolbar size /Skin/All/Menu.ini > ToolbarHeight
    Set Toolbar size (e.g. for GoTo Address) /Skin/All/Screen.ini >ToolbarButtonHeight
    Set List Slider width (e.g. To left of Addresses) /Skin/All/Screen.ini >ListSliderWidth
    Set Keyboard height /Skin/All/Screen.ini >OpenKeyboardHeight
    Set 'Near' menu buttons height /Skin/All/Screen.ini >ActionMenuButtonHeight (Horizontal)
    Change 3D Colors /Skin/All/View3dDesc.inf
    In post 9, what setting did you change to get the Map/Settings/More/Quit buttons taller ??
    I've managed to get other buttons taller and change the fonts in most things but those three buttons across the bottom don't want to change size.
    Forget that, I didn't read properly. I was changing stuff in screen.ini the one I needed was
    Now I need a UK map that will work properly. My D6 UK map works with CF but if I run it outside CF then trying to access the POIs crashes D6.
    Old setup
    Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
    New setup
    Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
    Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
  4. #34
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Any chance you guys that have it working can share the inf files you have done ?
    Terran
  5. #35
    FLAC djmickyg's Avatar
    Feb 2004
    yes please?
    I don't seem to have this skin folder in my destinator 6 sdk..
  6. #36
    Oct 2003
    Madrid
    Quote Originally Posted by djmickyg View Post
    yes please?
    Then you don't have D6 ;-)
  7. #37
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by ccsnet View Post
    Terran
    [shameless plug]Traffic Cams now has Madrid[/shameless plug]
    Ps some of the Carputer links on your site seem to be dead. Plus you're missing mine
  8. #38
    May 2005
    Derbyshire, UK
    Far from perfect.....
    Attached Files Attached Files
    Old setup
    New setup
  9. #39
    Jan 2003
    Its a start though
    Terran
  10. #40
    Nov 2004
    France
    A great Thanks to Laidback for his discovery.
    Last week i got this :
    It's less flashy than white bars but i can't hide all white buttons and can't change font'color.
    I wanted white font in status bar as in Destinator PN.
    Statusbar can be transparent and need a bigger height to display information.
