Results 1 to 9 of 9
Thread: Help modify screen size from software...
    Tainted Love Cris's Avatar
    Romania
    So I just replaced my original nav screen, that was a 6.5" one with a 7" touch screen. Unfortunatly, the new screen being a little bigger than the factory 6.5" location, a small part at the bottom of the screen is not viewable anymore...(my computer, taskbar, system tray...) The monitor settings don't allow image resizing (not to this extent, as you already know), so I need a solution to modify the screen size from &' to 6.5"...? Any ideeas?
    P.S At Darque's suggestion, I tried Powerstrip, but that only moves the image a little bit...but I need something to shink the image, not only move it...
    Romania
    Romania
    Well, here is the problem as you can see in the images below...from the driver's view port you can't see the bottom part of the screen. What can I do, software wise, to "lift" up that bottom area...?
    Newbie CanuckMark's Avatar
    Feb 2009
    Orillia, Ontario, Canada
    Can't help you with changing the actual resolution, but you can move the entire taskbar to the top of the screen for the time being - just "unlock" the taskbar (if it currently is locked) and drag it up.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If you want no software to use the bottom portion of the screen, you can resize the taskbar so that it stays with that area empty on the bottom. The only issue will be if you open a lot of applications at the same time (which will create more buttons that will fill up that area).
    In the case of front ends, I know for a fact that some (maybe not all) of them allow you to set the "usable" area where it should display the screen/skin.
    I had to do that myself because I lost about 15 pixels (height) of my screen due to the same exact reason.
    Ride Runner RR's Myspace
    May 2006
    Calgary, Alberta
    Why software? There should be controls on the monitor to change the screen size however you want.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Romania
    Quote Originally Posted by guino View Post
    Thanks Guino! The taskbar thing is pure genius. I now stop and wonder how come that ever crossed my mind...
    As fo the frontend, I'm a long time proud and happy RR user , but again...I haven't stumbled upon that option...where can I set the "usable" are from?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Cris View Post
    Adjusting it for RR is the easy part... just go into your skin folder, open general.ini (i.e. notepad) and where it says ShowHeight=600, decrease it to ShowHeight=570 or something like that.. you'll have to try a few numbers to see what works best based on your screen's position. Everything in RR will obey that setting including embedding applications, etc.
    Romania
    Thank very very much Guino!
  1. BMW E46 - What size Screen?
    By rikblacketer in forum LCD/Display
    Last Post: 10-11-2006, 11:20 PM
  2. Adjusting screen size for video (4:3, 16:9)
    By lookinco in forum StreetDeck
    Last Post: 09-28-2006, 04:34 AM
  3. Comps Specs and Screen Size
    By Rocky388 in forum Newbie
    Last Post: 05-31-2005, 09:37 PM
  4. Replies: 8
    Last Post: 09-17-2004, 01:17 PM
  5. Replies: 8
    Last Post: 02-03-2004, 06:17 PM
