Results 1 to 2 of 2
Thread: Volume Control out of balance??
    Mar 2004
    Sydney AUS
    Sometimes when booting(once booted), the computers volume control balance is shifted completly to the L/H. To fix it i minimise rr and open the volume controls and centre it again. does any one know if there is a quick fix for this to prevent it from happening or if i can insert a command during boot to always centre the speakers?? i am using rr and xp with a epia m1000 board if that makes any difference??
    Low Bitrate MOnline's Avatar
    Apr 2007
    Holland, Poeldijk (Near The Hague)
    Hi goatess,
    I searched the internet a bit and found a small program on This program has the capability to reset the values to what they where when windows shut down. It uses it's own saving file so it is not that dependable on what windows says.
    Why not try it. You should use the adminversion because it has the ability to start when windows does and save the settings / reset the settings (and thats what you want).
    With kind regards,
    FG van Zeelst
    Attached Files Attached Files
  1. Volume & Balance problem
    By cyberpeque in forum RR Bug Tracker
    Last Post: 06-17-2007, 03:17 PM
  2. Enhanced Volume Control
    By XxAndyxX in forum Software & Software Development
    Last Post: 06-12-2007, 09:25 PM
  3. Volume control in Xenarc 700TSV
    By BMW-7 in forum LCD/Display
    Last Post: 04-07-2005, 12:08 AM
  4. Resume from standby volume control problem
    By rjoek in forum FrodoPlayer
    Last Post: 03-08-2005, 04:55 PM
  5. hardware volume control
    By ODYSSEY in forum General Hardware Discussion
    Last Post: 04-20-2001, 11:43 AM
