Results 1 to 10 of 12
Thread: MeHere and Xport3
    May 2007
    MeHere and Xport3
    I'm going to install EVDO in my car PC soon and I wanted to make a plug in for CentraFuse so that I can start MeHere inside of the frontend. But I cannot get MeHere to work with Xport3.
    MeHere is a little application that allows you to be followed on google maps or in google earth. Here's the link: http://mehere.glenmurphy.com/
    Now because I'm already using several software packages for GPS tracking I have to use Xport3 so that they can all use the GPS info. However, MeHere only works without Xport3. For example, the GPS is at port 4. So when I don't use Xport3 and just hook MeHere straight up to port 4 it works perfectly. But when I start Xport3 and replicate the GPS signal on port 5-9 and try MeHere on any of these com ports the application will state that it found the GPS device. But then refuses to load the location.
    Any help is appreciated!
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Well, that's an interesting way to access the serial port... Heh, ok get the new XPort and it will work.
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by Curiosity View Post
    Still didn't work for me!
    Mar 2004
    Florence Yall, BFKY
    I just tried something else so get it again. Make sure you clear your cache or check the file version. It should say 1.12 as the version. It's working for me, but when I zoom in and it goes off the map, it doesn't scroll. Is that normal?
    May 2007
    Let me check the version
    May 2007
    Mine still hangs on "attempting to obtain GPS coordinates" while stating that it was able to connect to the com port.
    Mar 2004
    Florence Yall, BFKY
    Give it some time. It will say that until after it gets a sat lock.
    May 2007
    But it tells me that for at least 15 minutes...
    I went to go get some groceries and during the entire trip it wouldn't get a lock?
    But at the same time iGuidance and Destinator instantly got a lock.
    Mar 2004
    Florence Yall, BFKY
    That's what happened to me too. I got it working with the sim and assumed it was OK, but then I took it out tonight and it didn't work in the car. MeHere seems to toss out data if it's not timed at about 4800 baud or something and just gives up because XPort passes it in small chunks as it gets it. I've got a fix and you can download the latest, but I still need to test it with SiRF, other baud rates and all the other software.
    Jun 2007
    NY
    Does google have any applications that do something similar?
    Does MeHere only work with serial gps receivers? what about usb?
