i would reccommend XP since its more compatible with software that has been developed here for your car.
in order to get Vista back on your computer, you would have to boot from the Vista OS install disk, format your harddrive (much better than upgrading from a prior XP install) put in your serial when you re-install Vista whenever it asks you. activate your Vista automatically (its an option you select during the install process)
its not hard to reinstall an OS...and if you happen to mess it up, its an easy fix...
LinkBack URL
About LinkBacks
I'm going to look them up and see if there are any for xp before i put it on, or should xp have generic ones that will work?
