Results 1 to 6 of 6
Thread: usb power setting in bios?
    May 2006
    Belgium
    Hi, my usb devices draw a lot of power when my pc is shut down (or in standby) so i wanted to change the setting that i don't want any power going to them when pc is not running, but i can't find that option in my bios...
    i have a via mobo, running phoenix bios... anyone can tell me where to look?
    thx in advance
    Greetz
    Dj NRG
    Elsewhere
    That's more a function of the power supply, not the PC's BIOS.
    How about the Wiki?
    May 2006
    Belgium
    and how can i change that? i use an opus 150 watt power suply...
    Greetz
    Dj NRG
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    This has nothing to do with the power supply.
    Click on START >Control Panel > System > Hardware > Device Manager
    Find your USB Device, right click and select properties. Click the Power Managment tab and select
    "Allow the Computer to turn off this device to save power." Now when you hibernate or go into standby the usb device will be turned off.
    May 2006
    Belgium
    right... I know i had seen it somewhere...
    thx
    Greetz
    Dj NRG
    May 2006
    Belgium
    just checked in my car, and it was allready set to that.
    still my usb is taking somehow power. when i let the usb cables plugged in, it uses 6 watt, when i unplug the cables my pc uses 1.2 watt...
    can anyone tell me if this is normal? can someone measure at his pc what it uses with usb in and unplugged?
    Greetz
    Dj NRG
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 08:35 PM
  2. Replies: 6
    Last Post: 12-27-2005, 01:41 AM
  3. USB power issues - opinions please
    By zaxxon in forum Power Supplies
    Last Post: 07-20-2005, 10:03 PM
  4. Xenarc - USB Power cable?
    By Coeus in forum Power Supplies
    Last Post: 01-13-2005, 08:07 PM
  5. usb accessories, how much power do i need?
    By chris in nh in forum Newbie
    Last Post: 06-01-2004, 08:17 PM
