I checked through reshack and cant find the menu or info. Any help would be appreciated.
New Age Garmin - Skin for RR
I haven't find a way to do it with resource hacker. But if you are intended to do it with RoadRunner, RR has a redraw function that can trim the bottom part. If you look at RR's code, the function is in API module. I forgot the function name but that one is easy to find because it has a portion to trim IG window. That function take in 4 parameter for size. I think I add or subtract 20 pixels to have it trim to what it is now. Instead of 20, just add/subtract more to trim the bottom. Look around and you will find it.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
