Results 1 to 3 of 3
Thread: preventing audio jolts on startup
    Nov 2006
    I've done a search and found nothing, so I have a question. When i start my car-pc and boot into road runner, i find that the music is jolty on and off while the computer loads up fully at start up. It's a bit of a niggling thing really. I'd rather have it not start playing at all until it's able to play the music persistently without cutting in and out as a result of other things loading up in the background.
    Has anybody come up with a solution to this to prevent the jolty sound at PC startup? I've found its even worse at startup when using Bit-perfect, but still a problem without Bit-perfect too. Any advice/existing solutions for this?
    Oct 2004
    Sydney, Australia
    Your computer is out of resources while booting, have you got unnecessary programs on there? Try alt, ctrl, del when computer starts and see what process is taking the most resources. If you cant pin point anything try down grading your winamp to the old classic one, it uses like 1/10th the resources.
    Continued Worklog... Upgrades in progress:
    *15.4" WXGA LED backlight touchscreen upgrade
    *Custom fiberglass dash bezel
    Nov 2006
    After some experimentation, I've found out that it's alot more noticable using an ASIO output driver than using the DirectSound one. Pitty the ASIO one sounds better (at least once it's loaded). Also i don't think the older version of Winamp supports any ASIO plugins.... hhmm i'm revising the whole system now though to get boot times down and minimise resource usage elsewhere, so hopefully that will fix the problem.
  1. PCI Audio vs. USB Audio vs. Onboard Audio
    By waltwalt in forum Car Audio
    Last Post: 07-26-2007, 08:36 AM
  2. 2005 BMW E46 CarX audio hook-up question?
    By reggs in forum Hardware Development
    Last Post: 09-24-2005, 03:06 PM
  3. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 08:40 PM
  4. Replies: 19
    Last Post: 12-04-2004, 05:37 PM
  5. Seperate VGA and S-Video with Audio
    By Fox_Mulder in forum General Hardware Discussion
    Last Post: 07-01-2004, 01:44 AM
