Results 1 to 10 of 12
Thread: Linux Frontend?
    Newbie paragraph's Avatar
    Aug 2007
    Friggin' New Joysee! Sirius Station: 27 HardAttack
    Linux Frontend?
    Ok, beat me if i'm missing something, but are there any good linux based frontends?
    Particularaly, are there any that support the DeLorme Earthmate LT-20?
    I could use windows, but i'd rather go linux due to the lack of decent specs on my laptop.
    Thanks a million.
    '93 Camry - Work Log
    Progress (Slow and Steady)
    Phase 1: Planning and Software Procurement
    Total Cost So Far: $75
    Free Laptop Parts (DVD ROM!)
    Low Bitrate Thelgord's Avatar
    Jan 2007
    Wahiawa, HI
    I myself am quite surprised at the lack of interst from the linux community in this area. They put Linux on everything, even on a game boy... let me know what you can dig up, so far my searches have turned up very little.
    CarPuter
    Planning....[||||||||||]60%
    Parts.......[||||||||||]20%
    Construction[||||||||||]0%
    Software....[||||||||||]0%
    Aug 2007
    Well, i found GPS software (with work-arounds for the LT-20), and i know there are media-centers, but no carpc frontends.
    Linux would be great (read perfect) for carpc applications, small sysreqs, and can be built on small footprint PCs with low power options (eg: a nano-itx box with a small compact-flash card instead of a hard drive)
    tis a shame...
    Jan 2007
    Wahiawa, HI
    yet another reason i should learn c++
    CarPuter
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Simple reason is because there is lack of GPS support on Linux.
    If there is an easy GPS solution available on Linux, people would be all over it already.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Aug 2007
    Quote Originally Posted by MatrixPC View Post
    gpsd isn't too bad
    another great reason is the upcoming via eden processor. It only consumes 1w when it's running, the downside is it runs at 500mhz, thats well below the threshold for windoh's. But a linux box rocking one of these would be uber usable.
    Well, i'll have to settle for windows, that or try and hack together something with reactos.
    Jun 2006
    Chicago, IL
    not really you have to use windows, I use linux, and for gps I run iGuidance under wine, it works very quick and I don't even have regular hard drive, everything fits just fine on my CF card (2GB). All the media I keep on another SD flash card. I don't even need any specific frontend. As a window manager I use Windowmaker, and just switch desktops for different apps. On top of it, it loads within 28sec,works very quick, and even if I cut the power without shutting down, it never gets screwed up. Windows will.
    I think you should re-consider linux as your platform.
    All the things I mentioned you can achieve without writting even one line of c++ code.
    EPIA TC 1G 256MB 60GB Linux,WindowMaker, Roadnav, Xine, XMMS, iGuidance3
    Lilliput 8", Pharos i360, WUSB11v2.6 WiFi
    Aug 2007
    i'm looking for an all in one media-center/gps
    Linux will do both of those, but there arn't any programs that bridge the two.
    Jun 2006
    Chicago, IL
    you didn't understand what I was trying to say, better go for windows with any of carpc apps like RR od SD
    Newbie kshots's Avatar
    Mar 2007
    florida
    I can name several linux frontends:
    1. nGhost - Relatively mature frontend at this point. Utilizes C++, mysql (or sqlite, depending on your plugin), SDL and libtool. Can be configured remotely if you also run an apache server with PHP support. I wrote the current database plugin architecture myself
    2. Velocity - Java / Flash-based front end. Probably a bit heavy for your case, but it's had some time to mature (well before I started my own project)
    3. Evil Car PC - This one's my brain-child. Still in early stages, but a basic release has been made with a very basic plugin suite (mostly a product demo, really, to show how things work).
    If you want to go really light, I'd recommend nGhost - you don't even need X for that (it can work in framebuffer mode). As far as maturity goes, I'd recommend either nGhost or Velocity as mature options. If you want to get your hands dirty on a really powerful architecture (not sure if that's for you), go with Evil Car PC.
    I also suspect there's quite a few others that I've missed. I wouldn't mind someone pointing them out - I'm curious to see how many different approaches we have here.
  1. New Frontend for Windows and Linux
    By gbr in forum Other Cool Front Ends
    Last Post: 01-21-2009, 09:55 PM
  2. Getting started: Linux Frontend
    By Squidge in forum Newbie
    Last Post: 12-23-2006, 11:14 AM
  3. The best frontend for linux
    By xens in forum Newbie
    Last Post: 10-14-2006, 05:44 AM
  4. Silverwolf linux frontend
    By intuitionsys in forum Software & Software Development
    Last Post: 12-02-2005, 03:10 PM
  5. The LOW Risk Linux Adventure...
    By grepzen in forum Software & Software Development
    Last Post: 11-08-2004, 10:12 PM
