Results 1 to 10 of 14
Thread: Possible to run Windows Mobile 5 or 6 on a Mini-ITX Mobo?
    Aug 2004
    Bundaberg QLD AU
    I am wondering if anyone knows if its possible to run Win Mobile 5 or 6 on a standard Mini-ITX mobo (one i'm interested in is the Via M10000)..
    Reason i ask is it would allow quicker boot process, (maybe able to hibernate like a pocket PC?)
    And the main reason is all the decent GPS software is available on PPC and basically none on WinXP so it would make it easy to setup the GPS software...
    Any ideas?
    Constant Bitrate will_santana's Avatar
    Mar 2007
    Rio de Janeiro/Brasil
    do a little more serch
    there's no way to run windows mobile on a pc based hardware
    you can emulate it WITHIN windows, but not run it as operational system
    there's a lot of ways of speeding up the boot time (there's a sub forum just for it)
    and yeah, there's lot's of good navigation soft too (even destinator if that's what you mean)
    []s
    Mar 2004
    You should search yourself.
    Windows Mobile... which is built from Windows CE can be run on x86 PC hardware, however, Windows CE is built hardware specific for each application and isn't available like WinXP or Vista for you to just install. You have to buy the Windows Embedded dev kit for $1,000 and build a configuration for your hardware platform. Hope for a board support kit from the mobo maker (Via has them for their boards), because you might be writing your own drivers otherwise.
    FLAC sama's Avatar
    Feb 2006
    London, UK
    this is true. I've looked into writing a front end using CE, but it's not a practical generic solution. There are apps out there that will write generic drivers for you, but you're looking at third party dev kits which are pricier than the MS ones, since they make it a bit easier for you.
    I guess the answer to the question is it is possible but not practically
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Quote Originally Posted by jmbickham View Post
    WinCE and Windows Embedded are two different things. You can download the development kit for free (either one) but any device you "build" will have to be licensed within a certain time frame (120 Days?) or it will stop working. The development application for Window CE is called "Platform Builder". You can build a specific device onto a Pocket PC or an X86 PC. They will be different though. Most commercial software that was written for a Pocket PC won't run on an X86 platform without some serious trickery. Same goes for drivers needed to run Pocket PC devices, most are not written for X86 platform.
    I wanted to use WinCE for my CarPC when I first got started and came to the conclusion that it wasn't practical.
    ~Jimmy
    Mar 2007
    that's wath i meant when i said he can't have it as OS
    guess nobody wanna recompile a OS and all it's apps for a new plataform just to get a carpc working
    if you got the time and code you can recompile anithing to any plataform. but guess it does not worth the time and work
    []s
    FLAC sama's Avatar
    Feb 2006
    London, UK
    there is a linux project however, and that's sort of a compiled-for-carpc project. can't recall what it's called, but it's on here. ice or something
    Low Bitrate Thelgord's Avatar
    Jan 2007
    Wahiawa, HI
    Windows OSXP/VISTA)
    Runs all your apps
    is a "real" pc
    slower boot times
    can become unstable
    Windows CE/Mobile:
    Need "mobile" versions of apps
    not really considered a pc because of above statement
    faster boot times (generally speaking)
    more stable
    higher cost
    Windows Embeded:
    Runs all your apps (maybe)
    is a segemented version of windows xp pro
    you can leave out any part of windows xp to make it smaller/boot faster, but then apps that require that part wont run (ie media player, internet explorer) wont work.
    All your "normal" xp compatable drivers will work
    CarPuter
    Planning....[||||||||||]60%
    Parts.......[||||||||||]20%
    Construction[||||||||||]0%
    Software....[||||||||||]0%
    FLAC sama's Avatar
    Feb 2006
    London, UK
    Windows Embedded:
    It's a bloody pain I tried it and when drivers go bad, they go really bad. Things like multiuser being taken out mean that some s/w that is programmed to rely on this doesn't work. Such software was the bluetooth drivers I used, and all sorts of other stuff just didn't work properly. Something to be aware of should you want to try it out.
    Mar 2007
    there's no where to run
    you can rip off XP (or win98) to fit your own particular needs, or work with the full system (till you find what you REALLY need)
    guess the full system is the way to go. specially on a project start. and let the downsizing to the tweakin before
    []s
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 08:12 PM
  2. Run WinCE & XP together
    By ShawJohn in forum Software & Software Development
    Last Post: 11-07-2005, 05:09 PM
