Results 1 to 8 of 8
Thread: Bios boot
    Sep 2007
    NY
    Bios boot
    Anyone know where I can get a jeep image that I can use for my dell optiplex gx150 carputer. I hate seeing the dell logo on boot, it should be a jeep logo for my Jeeputer!!!!!!!!!!!!!!!!!!!!!!!!!! I also can't figure out exactly how to put that into my optiplex BIOS, seems a little different than others.
    Project Page - 1993 Wrangler Jeeputer
    Progress Meter {**-------} 15% most of the parts are in or have been ordered... Assembly has begun!!!!
    Jan 2006
    Lexington, KY
    I've seen some threads around for optiplex. can't seem to find them now.
    Sep 2007
    NY
    Yeah I did some pretty good searching and didn't find the optiplex threads... I was hoping someone remembered something about it, or better yet did it and can share :-)
    Dec 2007
    hy
    have modify the boot screen?
    Jan 2008
    Theres a program called theme xp that will help you modify your boot screen, login, and desktop theme. Although I would advise against using all the options since its a real memory hog.
    Once you've had the "Carputer" experience, you will wonder how you ever lived without it...
    Dec 2007
    i`m interesting to modify the bios boot screean and not windows.
    Under construct: Dell Optiplex GX 150
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by adamopel View Post
    It can be done, but it involves flashing the bios.
    Basically, change the image in the bios flash file.
    Sounds easy doesn't it?
    But:
    Get the colur depth, size, or anything else wrong and when you flash your bios you will probably end up with a "F'd" up mobo..............
    Google a bit and you'll find lots of instructions on it.
    *another thought just came to me*
    DEll used to have a utility that would allow you to change the bios image, but it was only for certain models (I use an optiplex gx 270 an it doesn't work on that model). Can't remember what it was called. Check it out on the DEll forums (that's where I ran across it), you may get lucky and it may work on your 150....
    Leonardo Da Vinci
    Dec 2007
    thanks, i will search some info on dell forum...maybe it can.
    i was thinking that @underwaterdan solved this
  1. Heat preventing system boot...
    By archaic0 in forum General Hardware Discussion
    Last Post: 06-29-2007, 10:46 AM
  2. DOH!! - Failed bios upgrade, what to do ?
    By cbyriel in forum Software & Software Development
    Last Post: 07-08-2006, 10:21 PM
  3. Intel Rapid BIOS for boot times anyone?
    By Nick1_S in forum Operating System Optimization
    Last Post: 03-31-2005, 02:56 AM
  4. boot problems
    By tracker92 in forum General Hardware Discussion
    Last Post: 05-20-2004, 04:21 PM
  5. What bios options for fast boot on EPIA M-1000
    By ugosplat in forum General Hardware Discussion
    Last Post: 08-13-2003, 09:42 PM
