i get a few different error messages
first one comes up right after Andi loads:
and heres the error it gave:
Code:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.FileNotFoundException: The specified module could not be found. (Exception from HRESULT: 0x8007007E)
at System.Windows.Forms.UnsafeNativeMethods.CoCreateInstance(Guid& clsid, Object punkOuter, Int32 context, Guid& iid)
at System.Windows.Forms.AxHost.CreateWithoutLicense(Guid clsid)
at System.Windows.Forms.AxHost.CreateWithLicense(String license, Guid clsid)
at System.Windows.Forms.AxHost.CreateInstanceCore(Guid clsid)
at System.Windows.Forms.AxHost.CreateInstance()
at System.Windows.Forms.AxHost.GetOcxCreate()
at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
at System.Windows.Forms.AxHost.CreateHandle()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.ControlCollection.Add(Control value)
at System.Windows.Forms.Form.ControlCollection.Add(Control value)
at AndiFull.frmbase.InitSkin()
at AndiFull.frmbase.frmBase_Activated(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnActivated(EventArgs e)
at System.Windows.Forms.Form.set_Active(Boolean value)
at System.Windows.Forms.Form.WmActivate(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
AndiFull
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/AndiFull.exe
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Interop.WMPLib
CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/Interop.WMPLib.DLL
Interop.SpeechLib
Assembly Version: 5.0.0.0
Win32 Version: 5.0.0.0
CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/Interop.SpeechLib.DLL
AxInterop.RemotePlayerCtrlLib
CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/AxInterop.RemotePlayerCtrlLib.DLL
WaveLibMixer
Assembly Version: 1.0.2834.38040
Win32 Version: 1.0.2834.38040
CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/WaveLibMixer.DLL
AxInterop.WMPLib
CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/AxInterop.WMPLib.DLL
AndiMpControls
Assembly Version: 1.0.2836.36400
CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/AndiMpControls.DLL
AndiIgHost
Assembly Version: 1.0.2836.34016
CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/AndiIgHost.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
second one comes up when i click on a album under jukebox:
Code:
Method 'OpenFile' cannot be invoked at this time.
mscorlib
AndiFull
System.Xml
System
System.Drawing
Interop.WMPLib
Interop.SpeechLib
WaveLibMixer
AxInterop.WMPLib
AndiMpControls
AndiIgHost
CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/Interop.RemotePlayerCtrlLib.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
enabled.
For example:
<configuration>
</configuration>
i also get a error message every time i click on something
