Page 12 of 15 FirstFirst ... 23456789101112131415 LastLast
Results 111 to 120 of 141
Thread: Upd8 1.0.8
  1. #111
    Newbie a_running_pir8's Avatar
    Mar 2008
    Fort Wayne, IN
    tada! that did the trick it seems like.....it went through and updated everything using "mdn" to mirror the host computer. I cant thank you enough for your work on this...once I get it completely skinned into DFX im going to release the code so that this program can be a major part of DFX because it is without a doubt becoming the best simple synchronization software out there. Thanks so much! and you got it all done the night before i leave for college
    Thanks again! If you need anything from me dont hesitate to ask.....I owe you one for this!
    PLEASE Visit My *Worklog*
    Tell me what you think!
  2. #112
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    No probs.
    I just thank you for your feedback, without which I wouldn't have know about these issues.
    I just wish more of the people that have downloaded posted their experiences with it.
    It's the only way I can improve on it.
  3. #113
    Mar 2008
    Fort Wayne, IN
    well....I just moved in today....this is my first post on my college internet connection but since I have a week till classes start, Ill get the skinning for DFX finished, and then maybe talk with JohnWPB about integrating it into DFX.....because I bet if more people knew about this then they would use it because I have tried many other synch programs and this was the simplest most complete one I found....so thanks!
  4. #114
    Mar 2008
    Fort Wayne, IN
    well....i spent a couple hours with photoshop....drawing up a very nice DFX skin for upd8....went to put it into the program....and got a runtime error 481....invalid picture
    I'm guessing it is because I saved the picture as a png in order to keep the transparency....a MUST in DFX....so....one more request
    Is it possible (easily) to enable transparency in upd8?
    Any help is appreciated thanks!
  5. #115
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Currently png images are not supported in any of my apps.
    Seeing as VB6 does not handle them natively.
    There are some GDI dll's similar to the one that Guino uses, but I can't get my head around them at the minute and can't be bothered to spend a lot of time on them at the moment to be honest.
    However now that I have a fair idea of how these RR extension plugins work I will try to make DLL plugins for RR for each of my plugins.
  6. #116
    Constant Bitrate smp4488's Avatar
    Oct 2007
    Louisville, KY
    I have Upd8 running but i keep getting errors during the sync. Here is my debug,
    10/11/2008|4:11:13 AM| Starter : Check for : C:\Program Files\Road Runner\Upd8\joygov.np
    10/11/2008|4:11:13 AM| Starter : C:\Program Files\Road Runner\Upd8\joygov.np doesnot exists, check for C:\Program Files\Road Runner\Upd8\updater.exe
    10/11/2008|4:11:13 AM| Starter : shell of C:\Program Files\Road Runner\Upd8\updater.exe did not happen, run C:\Program Files\Road Runner\Upd8\joygov.exe
    10/11/2008|4:11:13 AM|10/11/2008 4:11:13 AM : Debug file created
    10/11/2008|4:11:13 AM|Read Skin File
    10/11/2008|4:11:13 AM| load list labels
    10/11/2008|4:11:14 AM| load list labels
    10/11/2008|4:11:14 AM|Read Locations
    10/11/2008|4:11:14 AM| Entering update_screen
    10/11/2008|4:11:14 AM|Initialise
    10/11/2008|4:11:14 AM| Entering update_label
    10/11/2008|4:11:17 AM| Entering imgButtons_MouseDown
    10/11/2008|4:11:17 AM| Entering imgButtons_MouseUp
    10/11/2008|4:11:17 AM|Timer
    10/11/2008|4:11:17 AM|read PlayLists
    10/11/2008|4:11:17 AM| Entering update_label
    10/11/2008|4:11:17 AM|Searching Source root path : Z:\Music\
    10/11/2008|4:11:18 AM|Found Folder : 12 Peter Frampton
    10/11/2008|4:11:18 AM|Found Folder : 12 Stones
    10/11/2008|4:11:18 AM|Found Folder : 2004 The Girl Next Door
    10/11/2008|4:11:29 AM|Found Folder :Blink 182
    10/11/2008|4:11:29 AM|Found Folder : _Nancy Wilson
    10/11/2008|4:11:29 AM|Error routine
    10/11/2008|4:11:29 AM| Entering update_label
    10/11/2008|4:11:29 AM| Entering update_label 53 File not found
    10/11/2008|4:11:33 AM|Timer
    10/11/2008|4:11:33 AM|read PlayLists
    10/11/2008|4:11:33 AM| Entering update_label
    10/11/2008|4:11:33 AM|Searching Source root path : Z:\Music\
    10/11/2008|4:11:34 AM|Found Folder : 12 Peter Frampton
    10/11/2008|4:11:34 AM|Found Folder : 12 Stones
    I have changed folders and modes with no luck. I have the access.ok file. Any suggestions?
  7. #117
  8. #118
    Maximum Bitrate Dave One's Avatar
    Mar 2005
    Norfolk UK
    Great app E.
    Just one question - I've added
    "UPD8","load;upd8.skin;Update;C:\Program Files\RoadRunner\Upd8\Upd8.exe;joygov"
    to my RoadRunner ExecTBL.ini but there is no syncing when RR on starts up (with remote PC) or with Jumpdrive when RR is in main menu. This can be solved by pressing the Upd8 icon but should it automatically sync?
    Thanks again,
    Dave
    Vauxhall Astra SXi Car PC installed.
  9. #119
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    When you embed it in RoadRunner the program won't start ubtil you first visit the upd8 screen, once you visit that screen the program is loaded and thenit will do everything automatically.
    If you want it to be automatic wothout pressing the upd8 button you have three options.
    1. Start upd8 manually beforehand (put it in startup folder)
    2. Start upd8 when RoadRunner starts (there should be a command somewhere in RRConfig to start apps.
    3. Wait for RRUpd8 to be released from the beta stage.
  10. #120
    Mar 2005
    Norfolk UK
    Quote Originally Posted by Enforcer View Post
    I misunderstood the meaning of the ExecTBL.ini code. I thought that RR would instigate the Upd8 screen but I understand now.
    This is definately destined for the car very soon, after a little more familiarisation . And, of course, I'll provide feedback if I can provide constructive comments.
    Thanks,
    Dave
  1. Released: BETA 10
    By skippy76 in forum Road Runner
    Last Post: 03-07-2006, 11:53 AM
  2. StreetDeck Developer Edition Beta
    By Fiberoptic in forum StreetDeck
    Last Post: 01-23-2006, 03:18 PM
