Page 7 of 15 FirstFirst 123456789101112131415 LastLast
Results 61 to 70 of 141
Thread: Upd8 1.0.8
  1. #61
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I Need to change the font on the buttons, to match the original.
    Also need to do another screen for the path files once I have sorted out the program to do that
    But glad you like what I have doen so far.
  2. #62
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Do you see anything wrong with this ini?
    update.ini
    Code:
    [Locations]
    Loc1=C:\Media\Music,l:\Media\Music\,adn,*
    [General]
    Delay=55
    Minimized=False
    Pop=True
    Skin=Default
    Update=2
    Debug=True
    Debug.txt
    Code:
    14/07/2008|17:02:45| Starter : Check for : C:\Program Files\Road Runner\Upd8 1.0.8\Upd8\joygov.np
    14/07/2008|17:02:45| Starter : C:\Program Files\Road Runner\Upd8 1.0.8\Upd8\joygov.np doesnot exists, check for C:\Program Files\Road Runner\Upd8 1.0.8\Upd8\updater.exe
    14/07/2008|17:02:45| Starter : shell of C:\Program Files\Road Runner\Upd8 1.0.8\Upd8\updater.exe did not happen, run C:\Program Files\Road Runner\Upd8 1.0.8\Upd8\joygov.exe
    14/07/2008|17:02:46|14/07/2008 17:02:46 : Debug file created
    14/07/2008|17:02:46|Read Skin File
    14/07/2008|17:02:46| load list labels
    14/07/2008|17:02:46|Read Locations
    14/07/2008|17:02:46| Entering update_screen
    14/07/2008|17:02:46|Initialise
    14/07/2008|17:02:46| Entering update_label
    14/07/2008|17:02:53| Entering imgButtons_MouseDown
    14/07/2008|17:02:54| Entering imgButtons_MouseUp
    14/07/2008|17:02:54|Timer
    14/07/2008|17:02:57| Entering imgButtons_MouseDown
    14/07/2008|17:02:57| Entering imgButtons_MouseUp
    14/07/2008|17:02:57| Starter : C:\Program Files\Road Runner\Upd8 1.0.8\Upd8\joygov.exefinished
    14/07/2008|17:14:13| Starter : Check for : C:\Program Files\Road Runner\Upd8\joygov.np
    14/07/2008|17:14:13| Starter : C:\Program Files\Road Runner\Upd8\joygov.np doesnot exists, check for C:\Program Files\Road Runner\Upd8\updater.exe
    14/07/2008|17:14:13| Starter : shell of C:\Program Files\Road Runner\Upd8\updater.exe did not happen, run C:\Program Files\Road Runner\Upd8\joygov.exe
    14/07/2008|17:14:14|14/07/2008 17:14:14 : Debug file created
    14/07/2008|17:14:14|Read Skin File
    14/07/2008|17:14:14| load list labels
    14/07/2008|17:14:14|Read Locations
    14/07/2008|17:14:14| Entering update_screen
    14/07/2008|17:14:14|Initialise
    14/07/2008|17:14:14| Entering update_label
    14/07/2008|17:14:15| Entering imgButtons_MouseDown
    14/07/2008|17:14:15| Entering imgButtons_MouseUp
    14/07/2008|17:14:15|Timer
    14/07/2008|17:14:18| Entering imgButtons_MouseDown
    14/07/2008|17:14:18| Entering imgButtons_MouseUp
    14/07/2008|17:14:18| Starter : C:\Program Files\Road Runner\Upd8\joygov.exefinished
    Running it stand alone it loads ok displays the local/remote paths, when I select manual the text goes from white to red
    Access.ok is at the root of the L: (Flash drive) and the root of the C (Just in case)
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  3. #63
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Access.ok has to be in the path you specify, not the root of the drive.
    so you should have a access.ok file so:
    l:\Media\Music\access.ok
  4. #64
    Nov 2006
    Wales, UK
    Quote Originally Posted by Enforcer View Post
    solved!
    Using drive C as a test to see if these work
    in this version:
    Code:
    [Locations]
    Loc1=C:\Media\Music,C:\USB Drive\Media\Music\,adn,*
    Loc2=C:\Media\Video,C:\USB Drive\Media\Video\,adn,*
    Loc3=C:\Sygic Drive,C:\USB Drive\Sygic Drive Root\,adn,*
    Loc4=C:\Program Files\Road Runner\Skins\,C:\USB Drive\RR Skins,adn,*
    [General]
    Delay=10
    Minimized=False
    Pop=True
    Skin=E36
    Update=10
    Debug=True
    All copies are 100% apart from loc3. it copies everything in the directory but misses all the folders.
    What have i missed this time ?
    CarPuter Progress:
  5. #65
  6. #66
    Nov 2006
    Wales, UK
    Do the others have folders and do they copy correctly?
    Yea the others have alot of folders (mainly music)
    CarPuter Progress:
  7. #67
  8. #68
    Nov 2006
    Wales, UK
    Yea ive put random text files / pics in there, also tried just empty folders and still same results the files are between 100k-1mb
    CarPuter Progress:
  9. #69
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    strange
    There should be a update.log file in C:\USB Drive\Sygic Drive Root\
    have a look at that, it should say exactly what it has tried to do.
  10. #70
    Nov 2006
    Wales, UK
    strange
    It copied everything apart from the folders
    1 folder was called 7.54.999 the other 7.5.1.Fake (just to test if it works!)
    I renamed that folder to test and re-ran ,it copied over ok
    I also put folders in without spaces and .'s and they also copy ok
    Is there a chance it ignores folders with decimal places or long numbers cos every thing else copies over ok...
    Also ive noticed during the copy process the local location doesnt have anything appear in there until the progress bar has complete all the way (As opposed to using explorer and the files appear as they are copied)
    CarPuter Progress:
  1. Released: BETA 10
    By skippy76 in forum Road Runner
    Last Post: 03-07-2006, 11:53 AM
  2. StreetDeck Developer Edition Beta
    By Fiberoptic in forum StreetDeck
    Last Post: 01-23-2006, 03:18 PM
