System Information
Time of this report: 10/19/2007, 14:33:48
Machine name: CARPC
Operating System:
Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: Swedish (Regional Setting: Swedish)
System Manufacturer: CN400_
System Model: AWRDACPI
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: VIA Nehemiah, MMX, ~1.3GHz
Memory: 448MB RAM
Page File: 133MB used, 924MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found. Direct3D functionality not available. You should verify that the driver is a final version from the
hardware manufacturer.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name:
Manufacturer:
Chip type:
DAC type:
Device Key: Enum\
Display Memory: n/a
Current Mode: 1440 x 900 (16 bit) (42Hz)
Monitor:
Monitor Max Res:
Driver Name: RDPDD.dll
Driver Version: 5.01.2600.2180 (English)
DDI Version: unknown
Driver Attributes: Final Retail
Driver Date/Size: 8/4/2004 01:35:08, 92168 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: Saknas
Mini VDD:
Mini VDD Date: n/a, 0 bytes
Device Identifier: {D7B70EE0-4340-11CF-346B-282AAEC2C835}
Vendor ID: 0x0000
Device ID: 0x0000
SubSys ID: 0x00000000
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Ljuddrivrutin för Microsoft RDP (emulerad)
Default Sound Playback: Yes
Default Voice Playback: No
Hardware ID:
Manufacturer ID: 1
Product ID: 24
Type: Emulerad
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Full
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer,
Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Vinyl AC'97 Audio (WAVE), Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulerat], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mus
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Tangentbord
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB-rotnav (hub)
| Vendor/Product ID: 0x1106, 0x3038
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 23:08:44, 57600 bytes
| Driver: usbd.sys, 9/28/2001 16:00:00, 4736 bytes
+-+ USB Touchscreen Controller(Universal)
| | Vendor/Product ID: 0x0EEF, 0x0001
| | Matching Device ID: usb\vid_0eef&pid_0001
| | Service: xtouch
| | Driver: xtouch.sys, 10/15/2007 08:22:51, 81024 bytes
Gameport Devices
PS/2 Devices
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 01:35:06, 40840 bytes
| Driver: kbdclass.sys, 8/4/2004 01:18:46, 24832 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: mouclass.sys, 8/4/2004 01:46:42, 23296 bytes
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: , Half Duplex: , Mic:
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: Anslutning till lokalt nätverk 2 - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1,4 kbit/s
Voxware SC06 6,4 kbit/s
Voxware SC03 3,2 kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32,8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8,6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 17.8 GB
Total Space: 20.0 GB
File System: NTFS
Model: FUJITSU MHT2080AT
Drive: D:
Free Space: 55.7 GB
Total Space: 5.1 GB
File System: NTFS
Drive: E:
Model: MAT****A CD-RW CW-8124
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (Swedish), 8/3/2004 22:59:54, 49536 bytes
System Devices
Name: VIA CPU to AGP Controller
Device ID: PCI\VEN_1106&DEV_B198&SUBSYS_00000000&REV_00\3&13C 0B0C5&0&08
Driver: n/a
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1106&DEV_7259&SUBSYS_00000000&REV_00\3&13C 0B0C5&0&07
Driver: n/a
Device ID: PCI\VEN_1106&DEV_4259&SUBSYS_00000000&REV_00\3&13C 0B0C5&0&04
Driver: n/a
Device ID: PCI\VEN_1106&DEV_3259&SUBSYS_00000000&REV_00\3&13C 0B0C5&0&03
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_1106&DEV_3227&SUBSYS_00000000&REV_00\3&13C 0B0C5&0&88
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (Swedish), 9/28/2001 16:00:00, 36096 bytes
Device ID: PCI\VEN_1106&DEV_3149&SUBSYS_AA011106&REV_80\3&13C 0B0C5&0&78
Driver: n/a
Name: VIA/S3G UniChrome Pro IGP
Device ID: PCI\VEN_1106&DEV_3118&SUBSYS_31181106&REV_02\4&8CA 73A7&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\vtmini.sys, 6.14.0010.0342 (English), 10/19/2007 14:18:32, 269056 bytes
Driver: C:\WINDOWS\system32\vtdisp.dll, 6.14.0010.0342 (English), 10/19/2007 14:18:27, 3523072 bytes
Driver: C:\WINDOWS\system32\vticd.dll, 6.14.0010.0342 (English), 10/19/2007 14:18:31, 1888256 bytes
Driver: C:\WINDOWS\help\VTDspChs.hlp, 10/19/2007 14:18:27, 21467 bytes
Driver: C:\WINDOWS\help\VTDspCht.hlp, 10/19/2007 14:18:27, 22749 bytes
Driver: C:\WINDOWS\help\VTDspJpn.hlp, 10/19/2007 14:18:27, 22872 bytes
Driver: C:\WINDOWS\help\VTDspKor.hlp, 10/19/2007 14:18:28, 24036 bytes
Driver: C:\WINDOWS\help\VTDspWst.hlp, 10/19/2007 14:18:29, 233926 bytes
Driver: C:\WINDOWS\help\VTDspTha.hlp, 10/19/2007 14:18:28, 19340 bytes
Driver: C:\WINDOWS\help\VTDspWs2.hlp, 10/19/2007 14:18:28, 170362 bytes
Driver: C:\WINDOWS\help\VTGm2WST.hlp, 10/19/2007 14:18:30, 142400 bytes
Driver: C:\WINDOWS\help\VTGm2CHS.hlp, 10/19/2007 14:18:29, 17543 bytes
Driver: C:\WINDOWS\help\VTGm2CHT.hlp, 10/19/2007 14:18:29, 17421 bytes
Driver: C:\WINDOWS\help\VTGm2JPN.hlp, 10/19/2007 14:18:29, 16609 bytes
Driver: C:\WINDOWS\help\VTGm2KOR.hlp, 10/19/2007 14:18:30, 19205 bytes
Driver: C:\WINDOWS\help\VTGm2Tha.hlp, 10/19/2007 14:18:30, 18491 bytes
Driver: C:\WINDOWS\help\VTGm2Ws2.hlp, 10/19/2007 14:18:30, 104672 bytes
Driver: C:\WINDOWS\help\VTin2wst.hlp, 10/19/2007 14:18:32, 61309 bytes
Driver: C:\WINDOWS\help\VTin2chs.hlp, 10/19/2007 14:18:31, 9303 bytes
Driver: C:\WINDOWS\help\VTin2cht.hlp, 10/19/2007 14:18:31, 9760 bytes
Driver: C:\WINDOWS\help\VTin2jpn.hlp, 10/19/2007 14:18:31, 9582 bytes
Driver: C:\WINDOWS\help\VTin2kor.hlp, 10/19/2007 14:18:32, 10225 bytes
Driver: C:\WINDOWS\help\VTIn2Tha.hlp, 10/19/2007 14:18:32, 8070 bytes
Driver: C:\WINDOWS\help\VTin2ws2.hlp, 10/19/2007 14:18:32, 49147 bytes
Driver: C:\WINDOWS\help\VTovlwst.hlp, 10/19/2007 14:18:34, 72478 bytes
Driver: C:\WINDOWS\help\VTovlchs.hlp, 10/19/2007 14:18:33, 10567 bytes
Driver: C:\WINDOWS\help\VTovlcht.hlp, 10/19/2007 14:18:33, 10523 bytes
Driver: C:\WINDOWS\help\VTovljpn.hlp, 10/19/2007 14:18:33, 10504 bytes
Driver: C:\WINDOWS\help\VTovlkor.hlp, 10/19/2007 14:18:33, 11349 bytes
Driver: C:\WINDOWS\help\VTOvlTha.hlp, 10/19/2007 14:18:34, 8686 bytes
Driver: C:\WINDOWS\help\VTOvlWs2.hlp, 10/19/2007 14:18:34, 50989 bytes
Driver: C:\WINDOWS\system32\VTDisply.cfg, 10/19/2007 14:18:27, 63489 bytes
Driver: C:\WINDOWS\system32\VTDispl2.cfg, 10/19/2007 14:18:27, 56619 bytes
Driver: C:\WINDOWS\system32\VTDispl3.cfg, 10/19/2007 14:18:27, 52037 bytes
Driver: C:\WINDOWS\system32\VTDisply.dll, 2.01.0008.1018 (English), 10/19/2007 14:18:27, 651264 bytes
Driver: C:\WINDOWS\system32\VTGamma2.dll, 2.00.0037.0619 (English), 10/19/2007 14:18:29, 462848 bytes
Driver: C:\WINDOWS\system32\VTGamma2.cfg, 10/19/2007 14:18:29, 50215 bytes
Driver: C:\WINDOWS\system32\VTGama_2.cfg, 10/19/2007 14:18:29, 36546 bytes
Driver: C:\WINDOWS\system32\VTInfo2.dll, 2.00.0043.0619 (English), 10/19/2007 14:18:32, 327680 bytes
Driver: C:\WINDOWS\system32\VTInfo2.cfg, 10/19/2007 14:18:32, 44076 bytes
Driver: C:\WINDOWS\system32\VTovrlay.dll, 2.00.0041.0517 (English), 10/19/2007 14:18:34, 593920 bytes
Driver: C:\WINDOWS\system32\VTovrlay.cfg, 10/19/2007 14:18:34, 59327 bytes
Driver: C:\WINDOWS\system32\VTOvrly2.cfg, 10/19/2007 14:18:34, 34375 bytes
Driver: C:\WINDOWS\system32\VTTimer.exe, 2.00.0008.0921 (English), 10/19/2007 14:18:34, 53248 bytes
Driver: C:\WINDOWS\system32\VModes.exe, 1.00.0004.1027 (English), 10/19/2007 14:18:24, 28672 bytes
Driver: C:\WINDOWS\system32\VTCfg3d.dll, 2.00.0047.0719 (English), 10/19/2007 14:18:24, 417792 bytes
Driver: C:\WINDOWS\system32\VTCfg3d.cfg, 10/19/2007 14:18:24, 43390 bytes
Driver: C:\WINDOWS\help\VTcfgwst.hlp, 10/19/2007 14:18:26, 109209 bytes
Driver: C:\WINDOWS\help\VTCfgChs.hlp, 10/19/2007 14:18:25, 13008 bytes
Driver: C:\WINDOWS\help\VTCfgCht.hlp, 10/19/2007 14:18:25, 13271 bytes
Driver: C:\WINDOWS\help\VTCfgJpn.hlp, 10/19/2007 14:18:25, 10649 bytes
Driver: C:\WINDOWS\help\VTCfgKor.hlp, 10/19/2007 14:18:26, 13191 bytes
Driver: C:\WINDOWS\help\VTCfgTha.hlp, 10/19/2007 14:18:26, 9257 bytes
Driver: C:\WINDOWS\help\VTCfgWs2.hlp, 10/19/2007 14:18:26, 77945 bytes
Driver: C:\WINDOWS\system32\VTTrayp.exe, 2.00.0057.0927 (English), 10/19/2007 14:18:36, 176128 bytes
Driver: C:\WINDOWS\system32\VTTrayp.cfg, 10/19/2007 14:18:36, 51124 bytes
Driver: C:\WINDOWS\system32\VTTrayP2.cfg, 10/19/2007 14:18:36, 37162 bytes
Driver: C:\WINDOWS\help\VTtpwst.hlp, 10/19/2007 14:18:36, 105855 bytes
Driver: C:\WINDOWS\help\VTTPChs.hlp, 10/19/2007 14:18:35, 14728 bytes
Driver: C:\WINDOWS\help\VTTPCht.hlp, 10/19/2007 14:18:35, 14410 bytes
Driver: C:\WINDOWS\help\VTTPJpn.hlp, 10/19/2007 14:18:35, 13602 bytes
Driver: C:\WINDOWS\help\VTTPKor.hlp, 10/19/2007 14:18:36, 16213 bytes
Driver: C:\WINDOWS\help\VTTPTha.hlp, 10/19/2007 14:18:36, 11042 bytes
Driver: C:\WINDOWS\help\VTTPWs2.hlp, 10/19/2007 14:18:36, 88693 bytes
Name: VIA USB Enhanced Host Controller
Device ID: PCI\VEN_1106&DEV_3104&SUBSYS_31041106&REV_86\3&13C 0B0C5&0&84
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (Swedish), 8/4/2004 03:34:02, 75264 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 01:33:38, 7168 bytes
Name: VIA PCI 10/100Mb Fast Ethernet Adapter
Device ID: PCI\VEN_1106&DEV_3065&SUBSYS_01021106&REV_78\3&13C 0B0C5&0&90
Driver: C:\WINDOWS\system32\DRIVERS\fetnd5.sys, 2.66.0000.0290 (English), 8/17/2001 22:13:08, 27165 bytes
Name: Vinyl AC'97 Codec Combo Driver (WDM)
Device ID: PCI\VEN_1106&DEV_3059&SUBSYS_AA011106&REV_60\3&13C 0B0C5&0&8D
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (Swedish), 8/4/2004 01:33:42, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (Swedish), 8/4/2004 01:34:54, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (Swedish), 8/3/2004 23:15:22, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:00, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/3/2004 23:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (Swedish), 8/3/2004 23:08:04, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 01:34:56, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\vinyl97.sys, 6.14.0001.4070 (English), 9/6/2004 10:01:56, 161536 bytes
Name: VIA OHCI-kompatibel IEEE 1394-värdstyrenhet
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_30441106&REV_80\3&13C 0B0C5&0&68
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/3/2004 23:10:10, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/3/2004 23:10:08, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/4/2004 01:46:42, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/4/2004 01:46:42, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 23:46:40, 6400 bytes
Name: VIA Rev 5 or later USB Universal Host Controller
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_AA011106&REV_81\3&13C 0B0C5&0&83
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 20480 bytes
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_AA011106&REV_81\3&13C 0B0C5&0&82
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_AA011106&REV_81\3&13C 0B0C5&0&81
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_AA011106&REV_81\3&13C 0B0C5&0&80
Device ID: PCI\VEN_1106&DEV_2259&SUBSYS_00000000&REV_00\3&13C 0B0C5&0&02
Driver: n/a
Device ID: PCI\VEN_1106&DEV_1259&SUBSYS_00000000&REV_00\3&13C 0B0C5&0&01
Driver: n/a
Name: VIA Bus Master IDE Controller
Device ID: PCI\VEN_1106&DEV_0571&SUBSYS_AA011106&REV_06\3&13C 0B0C5&0&79
Driver: C:\WINDOWS\system32\DRIVERS\viaide.sys, 1.00.0001.0001 (English), 8/3/2004 22:59:44, 5376 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (Swedish), 8/3/2004 22:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:44, 95360 bytes
Device ID: PCI\VEN_1106&DEV_0259&SUBSYS_00000000&REV_00\3&13C 0B0C5&0&00
Driver: n/a
Name: Realtek RTL8139 Family PCI Fast Ethernet NIC
Device ID: PCI\VEN_10EC&DEV_8139&SUBSYS_813910EC&REV_10\3&13C 0B0C5&0&A0
Driver: C:\WINDOWS\system32\DRIVERS\RTL8139.sys, 5.398.0613.2003 (English), 8/4/2004 00:31:34, 20992 bytes
DirectX Components
ddraw.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:32 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:32 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 9/28/2001 16:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:32 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:32 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:32 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 9/28/2001 16:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:32 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 9/28/2001 16:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 9/28/2001 16:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 9/28/2001 16:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 9/28/2001 16:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 Swedish Final Retail 9/28/2001 16:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 229888 bytes
dpmodemx.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 9/28/2001 16:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 01:34:18 30208 bytes
dpnsvr.exe: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:34:18 17920 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:30:34 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:30:34 3584 bytes
dpvoice.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 01:34:18 83456 bytes
dpvvox.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 116736 bytes
dpvacm.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 60928 bytes
dpserial.dll: 5.00.2134.0001 Swedish Final Retail 9/28/2001 16:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 162304 bytes
dinput8.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 184832 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 9/28/2001 16:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 Swedish Final Retail 9/28/2001 16:00:00 395264 bytes
joy.cpl: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:34:54 68608 bytes
gcdef.dll: 5.01.2600.0000 Swedish Final Retail 9/28/2001 16:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:46:42 35328 bytes
dsound.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 71680 bytes
dmusic.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 82432 bytes
dx7vb.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 619008 bytes
dx8vb.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 9/28/2001 16:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 01:33:44 1028096 bytes
wsock32.dll: 5.01.2600.2180 Swedish Final Retail 8/4/2004 01:34:06 24576 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:33:30 70656 bytes
devenum.dll: 6.05.2600.2180 Swedish Final Retail 8/4/2004 01:33:32 59904 bytes
dxmasf.dll: 6.04.0009.1125 Swedish Final Retail 8/4/2004 01:33:34 498205 bytes
mciqtz32.dll: 6.05.2600.2180 Swedish Final Retail 8/4/2004 01:33:44 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 01:34:54 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:33:46 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:36 20480 bytes
qasf.dll: 9.00.0000.3250 Swedish Final Retail 8/4/2004 01:33:54 237568 bytes
qcap.dll: 6.05.2600.2180 Swedish Final Retail 8/4/2004 01:33:54 192512 bytes
qdv.dll: 6.05.2600.2180 Swedish Final Retail 8/4/2004 01:33:54 279040 bytes
qdvd.dll: 6.05.2600.2180 Swedish Final Retail 8/4/2004 01:33:54 385536 bytes
qedit.dll: 6.05.2600.2180 Swedish Final Retail 8/4/2004 01:33:54 562688 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:31:58 733696 bytes
quartz.dll: 6.05.2600.2180 Swedish Final Retail 8/4/2004 01:33:54 1289728 bytes
strmdll.dll: 4.01.0000.3928 Swedish Final Retail 8/4/2004 01:34:00 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 01:34:54 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 01:34:54 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 01:33:42 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 01:33:42 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 01:33:42 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 01:33:42 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 01:33:42 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 01:34:54 154624 bytes
mswebdvd.dll: 6.05.2600.2180 Swedish Final Retail 8/4/2004 01:33:50 204288 bytes
ks.sys: 5.03.2600.2180 Swedish Final Retail 8/3/2004 23:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:34:54 130048 bytes
ksuser.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:42 4096 bytes
stream.sys: 5.03.2600.2180 Swedish Final Retail 8/3/2004 23:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 Swedish Final Retail 8/3/2004 22:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 Swedish Final Retail 8/3/2004 22:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 Swedish Final Retail 8/3/2004 22:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:46:42 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 01:34:54 118272 bytes
msvidctl.dll: 6.05.2600.2180 Swedish Final Retail 8/4/2004 01:33:48 1431040 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 01:34:54 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:46:42 17408 bytes
wstdecod.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:34:06 51200 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2180
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2180
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.3250
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2180
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.402 6.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0 000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600. 2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.00 00
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 180
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000. 4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2180
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2180
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.3250
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.000 0
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2180
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.32 50
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2180
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.3250
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2180
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2180
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.07.0000.0001
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.3250
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000. 4487
DivX Demux,0x00600000,1,0,DivXMedia.ax,0.00.0000.0028
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.000 0
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2180
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600 .2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
DivX Subtitle Decoder,0x00600000,1,1,DivXMedia.ax,0.00.0000.0028
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.00 00
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2 180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0 000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.260 0.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 180
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2180
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2180
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2180
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2180
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2180
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2180
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 180
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2180
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
Datatransformationer för WDM-direktuppspelning:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.218 0
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 6.7 Codec (1 Logical CPU),0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 6.7 YV12 Decoder,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2180
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2180
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600 .2180
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2180
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Inspelningsenheter för WDM-direktuppspelning:
Vinyl AC'97 Audio (WAVE),0x00200000,3,2,,5.03.2600.2180
Renderingsenheter för WDM-direktuppspelning:
Mixerenheter för WDM-uppspelning:
Microsoft Kernel-wave-ljudMixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
Ljuddrivrutin för Microsoft RDP,0x00200000,1,0,quartz.dll,6.05.2600.2180
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2180
DirectSound: Ljuddrivrutin för Microsoft RDP (emulerad),0x00200000,1,0,quartz.dll,6.05.2600.218 0
Systemenheter för WDM-direktuppspelning:
Vinyl AC'97 Audio (WAVE),0x00200000,15,3,,5.03.2600.2180
