Windows Media Player and MSWebDVD!
I have been writing my front-end for a while now and been struggling with the DVD player part. I have posted a few questions on here about DVD playback. I have tried DirectShow (well I looked at it and didn't understand any of it). Then I started to use WMP, but for some reason I can only get audio through media player, no picture. So I turned to MSwebDVD! Seems like it should do the trick, but..... How do you tell MSWebDVD what DVD drive you are using? I have 2 DVD drives and a few DVDs on my hard disk, surly I should be able to access eaither drive or play DVDs of the hard disk...
I tried.....
MSWebDVD.dvddirectory="P:\video_ts\"
and
MSWebDVD.dvddirectory="M:\video_ts\"
and
MSWebDVD.dvddirectory="F:\dvd\video_ts\"
p: and m: are DVD drives, f: is a hard disk
....but all i get is "There is no DVD disc in the drive. Please insert a disc, and then try again."
Anyway, if I use this...
MSWebDVD.Play()
sometimes, it will play a dvd in one of the drives, then without doing anything different, I run the program again and get "No such interface supported", fustration
So after getting frustrated with MSWebDVD, I had another look at WMP. I downloaded and installed the NVidia DVD codec and at last I can see the video and hear the sound, things were looking good, apart from....
When using WMP to play a file, mpg, avi etc. you can use the command...
- mediaPlayer.Ctlcontrols.currentPosition =
to jump to a specific time, but when playing a dvd this doesn't work, nothing happens.
also
returns the position of where you are in seconds when playing a media file, but when playing a DVD it gives you the current time in the chapter.
Can anyone help with any of the niggles I have, any help would be much appriciated.
Update as regards to MSWebDVD
Right, if I run this code:
MSWebDVD.play()
and I have a DVD in P:, physical DVD drive, MSWebDVD will play my DVD from my hard drive f:
Without a DVD in the drive I always get the error message "There is no DVD disc in the drive. Please insert a disc, and then try again."
Why does there have to be a disc in the DVD drive to play a VIDEO_TS folder from the hard drive?
The microsoft website doesn't say anything about this.
Anyone else had this happen, and is there any sort of work around?
Thanks again
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
