Results 1 to 6 of 6
Thread: Need help w/ AutoIT copy file/folder script...
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    $origin and $destination are defined in Road Runner and passed to the script.
    This piece of code works except for the fact if $origin folder has sub-directories, it won't get copied over to the path defined by $destination.
    Code:
    $origin = $rr.getinfo("=$origin$")
    $destination = $rr.getinfo("=$destination$")
    ;Get origin info - file or folder
    $originarray = StringSplit($origin, "\", 1)
    $originarraycount = $originarray[0]
    $fileorfolder = StringInStr($originarray[$originarraycount], ".")	;Search string for "." to denote a file.  Otherwise, a folder
    If $fileorfolder == 0 Then
    	;Commands to execute if origin is a folder
    	FileCopy($origin & "\*.*", $destination & $originarray[$originarraycount] & "\", 9)
    	If FileExists($destination & $originarray[$originarraycount] & "\*.*") Then
    		$rr.execute("MENU;SUCCESS.skin||SETLABEL;!STATUS;Folder Copied")	;Confirmation skin
    	Else
    		$rr.execute("MENU;FAIL.skin||SETLABEL;!STATUS;Copy Failed!")		;Confirmation skin
    	EndIf
    Else
    	;Commands to execute if origin is a file
    	;MsgBox(4096,"Drive ", "It's a file")
    	FileCopy($origin, $destination, 1)
    	If FileExists($destination & $originarray[$originarraycount]) Then
    		$rr.execute("MENU;SUCCESS.skin||SETLABEL;!STATUS;File Copied")	;Confirmation skin
    	Else
    		$rr.execute("MENU;FAIL.skin||SETLABEL;!STATUS;ERROR! Copy Failed!")		;Confirmation skin
    	EndIf
    EndIf
    I've been searching the autoIT help for a few hours now and can't find a solution that will work. The DirMove works, but it deletes the $origin folder.
    Any help would be greatly appreciated.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Low Bitrate MOnline's Avatar
    Apr 2007
    Holland, Poeldijk (Near The Hague)
    Hi,
    When you copy only one file does this work.
    Because I can image that when you move an entire folder windows "recreates" it just like overwriting a file. If file copy works have you tried copying all the files in the folder instead of copying the folder itself ?
    With kind regards,
    FG van Zeelst
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    create a backup directory in the origin's location.. use dir move then after you've confirmed the move is complete just rename the backup to origins name. K.I.S.S Method ! lol
    Live mp3Car Facebook Chat
    Aug 2006
    Sun Diego
    Quote Originally Posted by MOnline View Post
    Hi,
    With kind regards,
    FG van Zeelst
    It copies all the files in the $origin directory.
    If there are subdirectories w/ files in the $origin, it won't get copied over, which is what I'm trying to do with just one copy command instead of multiple commands.
    Quote Originally Posted by Sonicxtacy02 View Post
    So how do I create a backup using autoIT? I'd still have to make a backup copy of $origin before being able to use DirMove to $destination, right?
    Aug 2006
    Sun Diego
    Problem solved.
    Found the DirCopy command...by accident when I mistakenly typed in xcopy.
    Lucky me.
    Apr 2007
    Glad to hear it you solved the problem
    With kind regards,
    FG van Zeelst
  1. Can someone make an autoit script for me?
    By Kamakazie2 in forum Software & Software Development
    Last Post: 12-23-2006, 07:37 PM
  2. Any AutoIt script experts out there?
    By mindracing in forum Centrafuse
    Last Post: 08-11-2005, 03:19 PM
