Results 1 to 3 of 3
Thread: Tag and Rename HELP!
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    So I attemtped using tag and rename. Not so good.....
    I found it is finding the albums however mizing all the tags umongst incorrect songs. The file name remains the original, however opeing the tag reveals a totally different song name> This is using the Amazon data base. It's finding the albums, and the songs, but when I write the tags there all mized up and maybe one or two came out correct? Any ideas?
    Elsewhere
    Be careful how you have them sorted before you write the tags.
    It's really easy to screw up tags if the files listed aren't in the order the tracks are on the album.
    Before you write the tags, you can manually assign what tag should be written to which file. It's a pain, but it it insures that you tag your stuff correctly.
    How about the Wiki?
    Nov 2007
    PA
    I figured, I'd just hoped there was an easier way. It seems tedious. I fugred there might be a program that could really do it auto most of the time...Thanks
  1. Browse-By-Cover....it's here!
    By juve021 in forum RR Skins
    Last Post: 08-16-2009, 03:51 AM
  2. Ratings plugin
    By Sonicxtacy02 in forum RR Released Plugins
    Last Post: 07-08-2009, 09:03 AM
  3. Not a plugin forsay. BUT EXTREMELY USEFUL!
    By JohnWPB in forum RR Plugins
    Last Post: 09-05-2007, 12:56 AM
  4. Centrafuse 1.5 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 01-14-2006, 08:03 PM
