OK i'm no C++ expert but i'm writing a simple directX application to watch TV, play mp3s, play DVDs etc...
My TV tuner card has inbuilt radio tuner, but i don't know how to change the source of the audio from the card to FM.... i presume it's by sending a command to the PCI card (well... the drivers for it). But i'm not sure how to do this?
I can decompile the program that came with it to get the commands, but how do i send it?
I sort of figured out how to send it with video for windows, but i HATE that way because it always crashes. Much more stable using direct show... and a lot smoother.. Other than source changing it's all working pretty sweet though
Still in majorly early beta though, i'm concentrating on getting the video and audio 100% crisp and smooth.... then i'll work on the interface...
Nah no activeX Control :|
does anyone know a good decompiler? i don't want the full source code of the app i just want sorta basic outline of what it's calling and with what methods and stuff.... should be able to be done.....
There are various applications that allow you to monitor DLL calls for a process. I would use one to view the software that came with the tuner, and then just program yours to use the same DLL.
Try ProcessViewer or the like...
OK thanks mate! just about to fire up google and go searching for that!!!
does anyone know how to access this? this is the capture device:
@devicenp:\\?\pci#ven_1131&dev_7134&subsys_01385168&rev_0 1#3&61aaa01&0&68#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
i mean i know it's the PCI adress (sumfin like that)
but dunno how to use it! coz im dumb![]()
PCI device enumeration is non trivial. Your best reference is probably the Linux source code. In particular, pciscan.c and pciscan.h. They are linked from (amongst other places) this network driver page: http://www.scyld.com/network/tulip.html
That pci address you posted contains the vendor id (manufacturer code) and the device id (chip code) which can be used to recognised the card during enumeration. I did this once for a graphics card under VxWorks to get a linear frame buffer, and it's nasty, nasty, nasty.
I recommend you find yourself a good PCI book to understand the process if you want to go this route.
Rob
if anyone's interested this is what im working on at the moment to go with my black interior..... what you think??
btw: going to be displayed on xenarc touchscreen![]()
