Results 1 to 5 of 5
Thread: Can't change map color in iGuidance 4
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Just what the title says. I can change day and night. Night is still white with flourecant writing and I can;t read it. Day looks white, not even yellow like it is supposed to be. If I click to change it to anything, fucia, gray etc...Nothing happens... I didn't touch anything to do with the file system either. Just like that form the install. Everything else works flawlessly...Any ideas? Thanks
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    delete theme.ini in the same directory as iGuidance.exe
    Nov 2007
    PA
    Ok? Will try it/...
    Nov 2007
    PA
    Well...Wow..? That worked!
    Jul 2005
    Motorcity
    Blog Entries
    1
    You can also modify theme.ini for different color schemes but deleting it will restore the defaults. Had a similar problem with iGuidance 3.0.
  1. Replies: 3
    Last Post: 08-05-2007, 01:41 PM
  2. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  3. Few Questions About Map Monkey and Destinator
    By Yevgeny in forum Map Monkey
    Last Post: 08-10-2005, 06:00 PM
  4. Replies: 0
    Last Post: 02-11-2005, 09:17 PM
