I'm using Centrafuse with the Silabs usb receiver (which btw as it turns out is the same module as the cheaper Brando receiver in a different case.)
Is there anyone out there using a FM tuner on their FRONTEND.
if so what one are you using, FE and tuner.
New at this just asking for a pointed finger in the right direction.
Anyone want to help me build one too a carpc
Thank you
I installed my carpc into my pet Kangaroo, mate.
RR
Visteon hd radio.
"Search" will turn turn up lots of stuff.................
Leonardo Da Vinci
RR + Shock Skin
Visteon HD tuner
Serial Interface
RR + MMIv2
Directed HD Tuner w/ mitchjs serial cable
Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
Was thinking about the Visteon HDZ300, but just realized my Motherboard only has one serial port! Maybe theres a USB to serial adapter, or mitch has something like that?
I'm using the Directed HD with Mitch's cable and a serial to USB adapter
TruckPC - gutted, being used for test setup
BoatPC - off season - Inelmac screen needs serviced again!
BlazerPC - last vehicle PC I'll build
