Results 1 to 10 of 10
Thread: Windows XP Splashscreen
    Sep 2000
    LA, CA, USA
    When windows is starting up, it shows the bootscreen which is easy enough to change especially with bootxp. But then the blue screen that says "Windows is Starting" comes up before the desktop is shown. Is there any way to prevent this screen from showing and have windows go right from the bootscreen to the desktop or to change these screens like the bootscreen can be changed? I have no idea where the image files are.
    Thanks.
    Sep 2000
    Saint Peter, Mn
    You can turn that off in the control panel. Uncheck the use welcome screen under user accounts.
    Sep 2000
    LA, CA, USA
    When I disable the welcome screen in the control panel, the login box comes up instead, which is even more annoying than the welcome screen. I'd rather just change the image like with the boot screen.
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    az1324,
    Get a program called tweakui. It is part of microsoft power toys. just do a google search for it. It can configure all different stuff in wondows that usually has to be done in regedit.
    How do I know this? I had the same thing happen to me when I tried to get rid of said splash screen.
    If you have any more dramas after that let me know....
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    also only having the administrator account only and no password on it makes the screen go away
    C4M
    C4M is offline
    Maximum Bitrate C4M's Avatar
    Apr 2002
    Sydney, Australia
    That's how I have mine set up, and although it means that you don't need to log the machine in, it doesn't get rid of the Welcome screen.
    C!
    http://carpc.riposte.net
    I reserve all rights in connection to each post I author, without exception.
    FLAC cproaudio's Avatar
    Aug 2002
    so cal 2 hours from everywhere
    On my system, even if theres no password, you still have log in. You just dont enter the password, hit enter instead. To have auto log in, you need to add a password then add/edit
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\Cu rrentVersion\Winlogon
    Value: ForceAutoLogon
    Type: REG_SZ
    Data: 1
    Value: DefaultPassword
    Type: REG_SZ
    Data: your password go here
    Value: AutoAdminLogon
    Type: REG_SZ
    Data: 1
    This will automatically log you into XP. every time. To check if you did it right, simply log off. XP will auto log in with out password.
    Low Bitrate The1Architect's Avatar
    Apr 2008
    Winnipeg, Canada
    Elsewhere
    Thanks for updating a 5.5 year old thread.
    How about the Wiki?
    Apr 2008
    Winnipeg, Canada
    lol didn't see the date .. just got it off the search
    >> > Design & Planning . . . . . . . . . . . . . . . . . . . . 100%
    > Software Installation . . . . . . . . . . . . . . . . . . . .98%
    > Hardware Installation . . . . . . . . . . . 55%
    >>> Overall Progress . . . . . . . . . . . . . . . . .85%
