Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Soft for Equalizer
  1. #11
    Maximum Bitrate MikeHunt79's Avatar
    Aug 2001
    Cambridge & Bristol, UK
    Originally posted by magnetik
    a dual 31 band software EQ..... phew... I hate to think of the CPU usage on that little baby!
    Hmm, i thought so too, so i had a little go with soundforge a minute ago, and was quite surprised. It only had a 20 band EQ which controlled both channels, but the CPU usage for real time playback was only 5% (even with quality set to high)! (see attached pic) My system is only a athlon 850, aswell.
    Say it took twice the cpu to process each channel independantly, it the usage would be 10%, but i`m not sure what the difference between 20 bands and 31 bands would be tho. I`m definately sure it would be doable with software (as long as youv`e got a pretty juicy CPU), just finding it won`t be easy.
    soundforge may do the task, but remember the solution would need to be running in the background - basically a windows 'service'.... receiving all sound card input, processing it and then passing on the result to the sound card to be processed... soundforge is basically an audio editor... not a real-time software DSP....
    I was only using soundforge as an example. Pretty much all of it processing features (including EQ) are also usable as directX plugins. If there was a directX plugin which was a 31band eq, i`m sure there must be another bit of software that allows directX plugins to be used in realtime, then your in business.
  2. #12
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    just get a pair of audio control eqt's
  3. #13
    Sep 2002
    Just North of Toronto, Ontario, Canada
    This site has a bunch of DX audio plugins, and other audio software:
    http://www.analogx.com/contents/download/audio.htm
    its got a DX delay plugin.
    Project AutoBoxen: Coming along, almost ready to hook up in the car.
    Celeron 500, 192mb ram, 8gb hdd, other stuff.
    '91 Mazda 626: Its free, so ill use it.
  4. #14
    Apr 2001
    Here, There, Everywhere
    nice find......!!!
    geez I would really like a DirectX normalisation audio plugin then... help normalise audio on both my mp3s and my DivX videos...
    and thanks for that MikeHunt79 - I really thought it would be more taxing on a CPU...?
    Project - GAME OVER :(
  5. #15
    Aug 2001
    No problem... I do know of way to normalize divx on playback however (its a directshow filter, rename to zip):
  6. #16
    C4M
    C4M is offline
    Maximum Bitrate C4M's Avatar
    Apr 2002
    Sydney, Australia
    If you're looking at IASCA, have a look at the Rane and Alesis stereo 1/3 octave EQ's - this is going to be a great deal more helpful to you in a competition car than a piece of software.
    I had an Alesis MEQ 230 in my car when I used to compete here in Australia, and it's an excellent solution to system EQ issues, especially given that they introduced zero noise into the system (measured with a CRO). I agree that the Audio Control units would be good as well, but if you're buying a pair, at least compare the prices for all three. Ranes are pretty pricey, but the Alesis are generally dirt cheap. I think the difference between them comes down to accuracy (Q).
    C!
    http://carpc.riposte.net
    I reserve all rights in connection to each post I author, without exception.
