Results 1 to 10 of 16
Thread: Soft for Equalizer
    Nov 2002
    North of France
    Soft for Equalizer
    hi i search a soft (or more) who can equalize the music in my car, but I need at less a 2x 30 bands (left and right)
    And something for a delay....
    thanks
    Watton
    MP3-Car
    www.DivX-Car.com
    Maximum Bitrate CarComp's Avatar
    Oct 2001
    Indiana
    Winamp has a built in equalizer.
    You probably won't find one with 30+ bands as software.
    Using software as an equalizer should be avoided.
    -CarComp
    Get MediaEngine !!!
    Media Engine Download
    Nov 2002
    North of France
    I'm using Winamp with en 31 band EQ, but i Want a dual 31 band EQ, this is for an IASCA Car
    MP3-Car
    www.DivX-Car.com
    Oct 2001
    Indiana
    You will have MUCH better results with a dual 31 band DJ equalizer
    Get MediaEngine !!!
    Oct 2001
    Ontario, Canada
    what is IASCA and why in gods name do you need a DUAL channel 31 band EQ?
    Unless you have a 10,000EUR stereo system in there, is that really necessary? :P
    IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
    Oct 2001
    Indiana
    IASCA = Acronym for "International Auto Sound Challenge Association."
    Iasca is to car audio like what NFL is to football. It pro stuff.
    Get MediaEngine !!!
    Dec 1999
    Buena Park, CA
    A dual 31 band channel equalizer is also known as a 1/3 Octave 2 channel equalizer. I use thes all the time at work to equalize PA systems, primarily when using microphones, especially lavaliers that are omnidirectional
    These are simply graphic equalizers with 31 different frequencies, this gives you a lot of control over the sound. However for car applications, it is usually more efficient to use a parametric eq, as there is not as much of a need for the capabilities of a graphic. A graphic is cheaper and easier to understand, however.
    I have not seen any software, besides high end audio software (primarily used in studio applications) that will actually perform the equalization (not to say that is doesn't exist, I just haven't come across it). One thought I had was to find a computer controllable eq (like Ashly's Protea or the BSS Soundweb system), converting it for use in a 12 volt environment, and using my in car computer to run the software for any tweaks that need to be made. I would also love to find an amp that I can control via computer for setting gains, switching channels on and off, and maybe even setting turn-on/off delays.
    Nov 2002
    Atlanta, GA, USA
    What's wrong with using software to do equalization? After layer 3, mpeg data is already in the frequency domain isn't it?
    Not sure if I've ever seen any software package that would do time delay. Would be nice if there was such a solution - using a multichannel sound card.
    Save virtual trees....
    Maximum Bitrate MikeHunt79's Avatar
    Aug 2001
    Cambridge & Bristol, UK
    If there was a software mp3player that allows directX plug-ins to be used, i`m sure theres a piece of audio software (soundforge?) which has an eq like you mentioned.
    Apr 2001
    Here, There, Everywhere
    a dual 31 band software EQ..... phew... I hate to think of the CPU usage on that little baby!
    I doubt such software exists, as CarComp has suggested you would be better looking at a hardware solution - since I doubt such software exists 'off the shelf' and secondly, it would put a large drain on the CPU....
    soundforge may do the task, but remember the solution would need to be running in the background - basically a windows 'service'.... receiving all sound card input, processing it and then passing on the result to the sound card to be processed... soundforge is basically an audio editor... not a real-time software DSP....
    Project - GAME OVER :(
