Results 1 to 8 of 8
Thread: Help with Remote Control Configuration
    Raw Wave
    Jun 2002
    Virginia
    Hello all,
    I am hoping the brains on this board can help me with this.
    I am using IRMan to control Winamp in a WinXP environment. Right now, I am using the Winamp plugin that came with the IRMan software to run Winamp. It is working fine for choosing songs, pause, etc.
    However, I would like to be able to use my remote control to also load Winamp. Any ideas about the best way to do that would be greatly appreciated.
    Also, a general question for those who are using Winamp: Are the Winamp plugin that comes with the IRMan installation disk and the Gen_IR Winamp plugin on the Evation website the same thing? If not, which is preferable?
    Thanks in advance.
    Kevin
    Variable Bitrate peter3's Avatar
    Feb 2001
    The Netherlands (deventer)
    take a look at this site. this program works with the Irman and let you do much more then just controle winamp.
    www.girder.nl
    Low Bitrate ZoLtRiX's Avatar
    Nov 2002
    Niagara Falls, Ontario
    PC remote
    I like PC remote better than guilder its much easier to use. If you need a crack for it let me know.
    Raw Wave
    Jun 2002
    Virginia
    Thanks for the replies, guys.
    Jay, what is PC Remote? Does it work with IRMan? Do I need a special remote?
    Nov 2002
    Yeah it works with IRman thats what im using. what it does is let you asign a key to a button on the remote, I use it with Markus`s LCD plug in with the keyboard commands. Ite easy to set up. and nice.
    Raw Wave
    Jun 2002
    Virginia
    Thanks, Jay. Where do I find the program? Can one use it to load as well as control Winamp?
    Nov 2002
    Yep, I have PC remote launch on startup up as well as winamp with Markus`s LCD software for winamp. and Im very happy with this setup.works nice.
    Raw Wave
    Jun 2002
    Virginia
    I actually don't want to have Winamp load at startup. I want to be able to launch Winamp with the remote. Will this program allow me to do that?
    Also, do you know where I can find the program?
    Thanks.
    Kevin
