Results 1 to 6 of 6
Thread: Webcam mirror/flip VB.NET help please?
    Sep 2006
    Cornwall, England
    Hi,
    I want to add a reversing cam to my project. I have some sample VB.NET code that uses avicap32.dll to 'get' the webcam and then opens a preview window in a picturebox on a form. Using a few Sendmessage commands, the webcam image is displayed in the picturebox.
    Everything works nicely apart from I would like the image to be flipped/mirrored, as it were if you were using a rear view mirroe. Is there any commands you have to 'send' the webcam via avicap32, or is it more complicated than that?
    ViVE - Volkswagen In Van Entertainment:
    VoomPC 2, VIA C7 2GHz
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    [||||||||||] 100% - Planning
    [||||||||||] 100% - Software coding
    [||||||||||] 100% - Built
    (Always tweaking!)
    Apr 2006
    Dallas, Texas
    What format is the video when you get it from the WebCam? You might be able to flip the X,Y coords of the image on-the-fly.
    Apr 2006
    Dallas, Texas
    http://www.codeproject.com/KB/audio-...ctShowNET.aspx
    Here's some code that allows you to grab the webcam information.
    Check out this article to see the image inversion..
    http://forums.microsoft.com/MSDN/Sho...13689&SiteID=1
    Sep 2006
    Cornwall, England
    Thanks for the reply, this is the code that I've just got working. It's basic, but it works, and I'll probably build on it...
    Imports System.Runtime.InteropServices
    Public Class Form1
    Const WM_CAP As Short = &H400S
    Const WM_CAP_DRIVER_CONNECT As Integer = WM_CAP + 10
    Const WM_CAP_DRIVER_DISCONNECT As Integer = WM_CAP + 11
    Const WM_CAP_EDIT_COPY As Integer = WM_CAP + 30
    Const WM_CAP_SET_PREVIEW As Integer = WM_CAP + 50
    Const WM_CAP_SET_PREVIEWRATE As Integer = WM_CAP + 52
    Const WM_CAP_SET_SCALE As Integer = WM_CAP + 53
    Const WS_CHILD As Integer = &H40000000
    Const WS_VISIBLE As Integer = &H10000000
    Const SWP_NOMOVE As Short = &H2S
    Const SWP_NOSIZE As Short = 1
    Const SWP_NOZORDER As Short = &H4S
    Const HWND_BOTTOM As Short = 1
    Const WM_CAP_CONNECT As Integer = 1034
    Const WM_CAP_DISCONNECT As Integer = 1035
    Const WM_CAP_GET_FRAME As Integer = 1084
    Const WM_CAP_COPY As Integer = 1054
    Private tempObj As IDataObject
    Private tempimg As System.Drawing.Bitmap
    Private mCapHwnd As Integer ' Handle of webcam
    Dim iDevice As Integer = 0 ' Current device ID
    Declare Function SendMessage Lib "user32" Alias "SendMessageA" _
    (ByVal hwnd As Integer, ByVal wMsg As Integer, ByVal wParam As Integer, _
    <MarshalAs(UnmanagedType.AsAny)> ByVal lParam As Object) As Integer
    Declare Function SetWindowPos Lib "user32" Alias "SetWindowPos" (ByVal hwnd As Integer, _
    ByVal hWndInsertAfter As Integer, ByVal x As Integer, ByVal y As Integer, _
    ByVal cx As Integer, ByVal cy As Integer, ByVal wFlags As Integer) As Integer
    Declare Function DestroyWindow Lib "user32" (ByVal hndw As Integer) As Boolean
    Declare Function capCreateCaptureWindowA Lib "avicap32.dll" _
    (ByVal lpszWindowName As String, ByVal dwStyle As Integer, _
    ByVal x As Integer, ByVal y As Integer, ByVal nWidth As Integer, _
    ByVal nHeight As Short, ByVal hWndParent As Integer, _
    ByVal nID As Integer) As Integer
    Declare Function capGetDriverDescriptionA Lib "avicap32.dll" (ByVal wDriver As Short, _
    ByVal lpszName As String, ByVal cbName As Integer, ByVal lpszVer As String, _
    ByVal cbVer As Integer) As Boolean
    Private Sub btnStart_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnStart.Click
    Try
    ' setup a capture window
    mCapHwnd = capCreateCaptureWindowA("WebCap", 0, 0, 0, 320, 240, Me.Handle.ToInt32(), 0)
    ' connect to the capture device
    SendMessage(mCapHwnd, WM_CAP_CONNECT, iDevice, 0)
    SendMessage(mCapHwnd, WM_CAP_SET_PREVIEW, iDevice, 0)
    'Set the preview rate in milliseconds
    SendMessage(mCapHwnd, WM_CAP_SET_PREVIEWRATE, 40, 0)
    Catch ex As Exception
    DestroyWindow(mCapHwnd)
    End Try
    Timer1.Enabled = True
    End Sub
    Private Sub btnStop_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnStop.Click
    ' Disconnect device
    SendMessage(mCapHwnd, WM_CAP_DISCONNECT, iDevice, 0)
    Timer1.Enabled = False
    End Sub
    Private Sub Form1_Closing(ByVal sender As Object, ByVal e As System.ComponentModel.CancelEventArgs) Handles MyBase.Closing
    End Sub
    Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
    Try
    ' get the next frame;
    SendMessage(mCapHwnd, WM_CAP_GET_FRAME, 0, 0)
    ' copy the frame to the clipboard
    SendMessage(mCapHwnd, WM_CAP_COPY, 0, 0)
    ' get from the clipboard
    tempObj = Clipboard.GetDataObject()
    tempimg = tempObj.GetData(System.Windows.Forms.DataFormats.B itmap)
    tempimg.RotateFlip(RotateFlipType.RotateNoneFlipX)
    PictureBox.Image = tempimg
    End Try
    End Sub
    End Class
    All I do is copy a frame to the clipboard from the camera every time the timer ticks. I then copy and flip the image to a tempory image object and then put the image in the image box.
    Seems to work OK, do you think this is a good method?
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    (Always tweaking!)
    Apr 2006
    Dallas, Texas
    Well, I am used to C# more so I'll try to translate. Basically you'll be doing the same thing, only you won't be using the clipboard since that can screw with other applications.
    The basic idea is to create a call back function (handler) so that every time an image is captured from the card, you can flip it.
    I started to try and convert it all to VB.NET from C#.NET but there is just too much I would need to define, instead I'll direct you to the C# code. I'm sure you can translate it as the languages are pretty similar.
    http://www.codeproject.com/KB/audio-...?display=Print
    If you need help with converting anything I should be able to do it for you. I'm just more confortable using C#.
    Sep 2006
    Cornwall, England
    Cheers. But I tried this and it keeps crashing.
    The code I have seems to work OK. Just need to buy another webcam and an extender cable and try it out!
    Cheers
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    (Always tweaking!)
  1. Logitech Orbit AF Webcam
    By hardcoreracing in forum Road Runner
    Last Post: 02-16-2008, 10:53 PM
  2. Experimenting with Dash Cam. Should I convert my webcam to infrared?
    By nobb in forum General Hardware Discussion
    Last Post: 02-16-2008, 08:56 PM
  3. Webcam Options
    By jschrauwen in forum Input Devices
    Last Post: 01-04-2008, 12:15 PM
  4. FAQ: How To Make An IR Webcam
    By rijndael in forum The FAQ Emporium
    Last Post: 09-03-2007, 01:35 PM
  5. VB.net and FMOD
    By bondbond55 in forum Software & Software Development
    Last Post: 03-12-2004, 10:56 AM
